Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-29-2010, 01:35 PM
*Registered User*
Glacern is on a distinguished road
Arrow Glacern Supported Linear Rails & Bearings
Just letting everyone know that our 20mm and 30mm SBR supported rails and bearings are now in stock at http://www.glacern.com/sbr.
They are currently at winter sale prices, and we're offering $4.99 flat shipping for orders over $99. We also have 30mm x 10 ft rails in stock, which ship by truck freight.
These are first of many automation products that we plan to add to our catalog. We're particularly excited about these rails, as we feel they're ideal for folks building their own routers and plasma tables thanks to the low cost, availability, and ease of installation.
We're fans of using aluminum T-slot extrusions for building CNCs since they're so easy to cut, join, and adjust. Our 20mm rails can be bolted directly to standard 60mm-wide aluminum extrusions (30mm T-slot spacing) without modification, while the 30mm rails can be bolted to standard 80mm-wide aluminum extrusions (40mm T-slot spacing). Likewise, the 20mm and 30mm rails can be adapted to "10 series" and "15 series" inch extrusions by simply drilling additional holes in the extruded aluminum T-support.
-Sol
Glacern Machine Tools
Old 01-29-2010, 09:46 PM
rcbamm is on a distinguished road
Could these rails be butted up against each other to make the overall length longer? Will you guys be supplying any longer 20mm rails in the near future?
Is the $4.99 shipping for as much as you order that isn't freight?
Old 01-29-2010, 10:41 PM
the4thseal is on a distinguished road
do you make an adjustable block(truck)? looks good.
Old 01-30-2010, 02:47 PM
*Registered User*
The rails can be butted up, but not straight out of the box due to the light chamfer ground on the ends of the shafts. Some careful grinding will be necessary. Yes, we can supply longer lengths in the future. What lengths were you interested in?
The bearings can be adjusted with a set screw on the top of the block. We don't offer the clamping style on the side of the block at the moment.
Thanks.
Old 02-10-2010, 06:42 AM
Zathras's Avatar
Zathras is on a distinguished road
I've converted a Super X3 a while ago but I have been thinking of building gantry type machine to eventually replace the X3 with larger travel and quite frankly more precision (hopefully).
Thinking I'd probably mount them on a steel tubular frame filled with concrete or E/G.
Do you think these type of rails would suit such a machine or are they for lighter work such as a router?
Old 02-10-2010, 08:16 AM
EBC's Avatar
EBC EBC is offline
EBC is on a distinguished road
Question
Do you have 30mm X 3050mm rails in stock Cost?
Gene Crain
www.plantasymaderas.com
servicio de fresadora cnc
Old 02-10-2010, 11:43 AM
Thazul is on a distinguished road
Any chance of you guys carrying a linear bearing/rail of the roller type, similar to the Hiwin RG Series?
Thanks!
Andy
Old 02-12-2010, 12:35 PM
*Registered User*
Gene Crain
Yes they are in stock at $249.99 each. Please email us for shipping, thanks!
-Sol
Tags
glacern, linear, motion, sbr, supported
Intermittently Supported Linear Ball Bushing Rails Chuck_M Linear and Rotary Motion 1 12-12-2009 10:57 PM
16mm vs. 20mm supported linear rails... WilliamD DIY-CNC Router Table Machines 4 12-19-2008 05:37 PM
Linear Rails and Bearings Robyn Product Announcements & Manufacturer News 3 08-30-2006 10:10 AM
Linear Rails/guides and Bearings - What size is best? Shawnusa Linear and Rotary Motion 9 10-29-2005 10:51 AM
Linear rails and bearings- overkill? pminmo DIY-CNC Router Table Machines 20 01-30-2004 03:43 AM
