Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-28-2010, 12:13 PM
cnczoner is on a distinguished road
Bearings = bearings?
I'm going to order new bearings for my HF geared-head mill spindle, but wondering if I should get aftermarket units. I'd like to also find ones that are the same dimensions, but can handle higher speeds, as I'll work on getting a faster motor or convert to belt drive later to get higher spindle speeds.
Are there any better brands of bearings I should look into?
Thanks,
-Neil.
Old 01-28-2010, 12:26 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Any of the name brand will be better than than no name chinese bearings. SKF, FAG, NTN, NSK etc...
Regards,
Mark
www.wrathall.com
Old 01-29-2010, 12:18 PM
What about VXB or Mcmaster (although their bearings are unbranded/unstated)? I tend to choose the easily-orderable sources (ie: online) before going to the wait-for-quotes sources. I might just try local sources too.
Old 01-29-2010, 12:26 PM
Fegenbush is on a distinguished road
cnczoner,
I just found a site last night while looking for Timken roller bearings.
www.bearingsdirect.com
They had the actual Timken bearing I was looking for at 1/3 the cost of McMaster, so you may want to check it out.
Fegenbush
Old 01-29-2010, 01:32 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Have you looked at SKF or NSK?? They carry all kinds of bearings for every application.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 01-30-2010, 03:56 AM
RotarySMP's Avatar
I generally buy bearings over Ebay. You can normally find everything except the really exotic P2 spindle bearings.
Regards,
Mark
www.wrathall.com
Newbie- bearings Ted coven DynaCNC 1 07-09-2009 05:00 AM
DIY air bearings daedalus Mechanical Calculations/Engineering Design 9 07-30-2006 10:44 PM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 10:06 AM
Double Bearings Or Quad Bearings? ballscrewed Mechanical Calculations/Engineering Design 5 04-18-2006 12:33 PM
Bearings (Radial Ball Bearings) The Bearing Man CNCzone Club House 0 12-18-2005 12:10 PM
