Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-13-2010, 03:18 AM
15mgtar is on a distinguished road
whipping screw?
Can someone explain to me what is a lead screw whipped?
What does it look like when that happends?
Old 01-13-2010, 03:34 AM
irving2008 is on a distinguished road
any long body when spun will have a natural resonance that will cause the unrestrained end to 'wobble' about centre (think of a ruler clamped end on to a desk and 'twanged', but rotating). If both ends are trapped then the centre starts to wobble (like a skipping rope held between two schoolkids)...
obviously when that happens there is a considerable sideforce on the leadnut leading to high wear rates plus vibration...
If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
Old 01-13-2010, 06:16 AM
I am using 2.1 meter leadscrew and I think it is whipping in the middle and causing alot of vibration on my cnc router. How can I fix this?
Old 01-13-2010, 08:10 AM
Andre' B is on a distinguished road
Use a larger diameter screw.
Old 01-13-2010, 08:12 AM
ger21's Avatar
Also, use a screw with a higher lead so it'll spin slower.
Old 01-13-2010, 09:15 AM
what dimensions are the screw - diameter, root diameter, pitch and how is it supported at each end... free (obvious), supported in a sliding bearing, able to move axially) or fixed (rigidly held axially as well as radially)?
It is possible to calculate the max rpm before whipping occurs...
While both are true, neither may be practical... larger diameter = more inertia = more torque to maintain drive speeds, higher lead = less resolution, may not be available... another thing to consider is how the screw is supported... moving to better bearing arrangements can double the critical speed for a given screw...
Old 01-13-2010, 09:55 AM
ger21's Avatar
Right, screws must be part of a matched drive system. Going with larger screws will possibly require changing other parts of the system as well. Everything needs to work together.
Old 01-13-2010, 10:47 AM
I give you practical in a hobby machine, but for production it just depends what you want/need and are willing to pay for.
The company I work for is currently looking at a new mill, it has ball screws about 16' long and 2" diameter the pitch must be 1.5 or 2 inches, and rapids at 1500IPM. Resolution is easy, expensive but easy, just put an encoder on it with several 100 thousand counts per rev..
As far as inertia, if you have ever played with model airplanes you know that if you put enough HP on it, almost anything can make a good airplane.
If you put 2 bearings on each end of the screw, spaced few inches apart all properly preloaded and in line it will work much better then bearings at a single point on each end.
Old 01-13-2010, 07:30 PM
I am using 2 units of Hiwin 5mm Lead, 25mm diameter and 2.1 meter long ballscrew with BK / BF 20 support blocks for the Y axis. At the middle I would say it is whipping good causing vibration. To solve this problem should I change the BF 20 to BK 20 so it's BK/BK20?
or getting a larger diameter and higher lead say 10mm lead 35mm diameter ballscrew (which is to cost me dearly) and BK/BF 25?
my stepper is size 42 nema and about 3200 oz/ in.
Please advice.
Old 01-14-2010, 05:57 AM
BillTodd is on a distinguished road
You could re-design the axis, so that the nut is rotated and the lead-screw kept stationary (i.e. mount the motor on the moving part and fix the nut in a pair of bearings)
http://www.cnczone.com/forums/showpo...03&postcount=8
Bill
  #11   Ban this user!
Old 01-14-2010, 06:24 AM
Please advice.
You dont say what speed you are trying to achieve but the critical speed for that screw in a fixed-supported (BK/BF) configuration is approx 3,825rpm, so whipping is very unlikely to be the issue.. even in a support-supported (BF/BF) is would be approx 2,467rpm (thats >12m/min and your motors wont even get close to that!)
However what you describe sounds like some sort of resonance in the system.
Is the vibration speed dependent? Is there a speed it starts to appear or one it peaks at?
Are you using one or two motors to drive the 2 screws and what configuration?
One thing I would suggest is removing the ballnuts (tricky i know) and spinning each screw in isolation... does it still vibrate then? Maybe one of the screws is slightly bent (over 2.1m even 1mm out of line will give a significant vibration).
  #12   Ban this user!
Old 01-14-2010, 07:35 AM
Putting additional bearings? Can you explain in detail please?
Will these solve my whipping problem?
Acme screw "whipping" Please Help. Ranscon Linear and Rotary Motion 11 10-07-2009 08:21 AM
Need help with X screw whipping Atechy Linear and Rotary Motion 2 01-04-2009 05:43 PM
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
ballscrew whipping walter Linear and Rotary Motion 2 06-18-2005 09:37 PM
