Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-08-2010, 11:02 PM
jtluttrell's Avatar
jtluttrell is on a distinguished road
Steps per Inch Question
A quote from buildyourcnc.com:
"Generally, the precision will be reduced with the increase of the turns/inch. "
Is this accurate?
Old 01-08-2010, 11:15 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Is this accurate?
Hi JTL. Welcome to the Zone!
NO, quite the reverse.
200 steps x 10 microsteps x 5 TPI= 10,000 Steps Per Inch, which is a resolution of .0001.
The above with 10 TPI screw instead= 20,000 SPI, which is a resolution of .00005
http://crevicereamer.com/Page_2.html
CR.
Too many PMs. Email me to my name plus At A O L dot com.
Old 01-08-2010, 11:24 PM
jtluttrell's Avatar
Whew! Thanks for the reply. After reading that article (at buildyourcnc.com), I had just about wrapped my head around the math when I read that quote. It threw me for a loop.
Thanks for the welcome.
I am new here, but hopefully I will be back again with many more questions as I start my build.
Old 01-08-2010, 11:26 PM
Read the link I gave you, it will help.
CR.
Old 01-09-2010, 06:49 AM
ger21's Avatar
Is this accurate?
The actual quote I found on his site is
If the pitch is too high, then resolution will be reduced
Which is correct. Either you mis-quoted him, or he has it written two different ways.
Increasing turns per inch reduces the pitch.
Old 01-12-2010, 06:48 PM
phooddaniel is on a distinguished road
Talking
Is this accurate?
Yep, totally my bad. This is the reverse and I have made the correction on the website. I also should have said the "resolution" and not "precision". You will notice that in my contextual narrative and in the video, the point still comes across that the resolution does increase with the increase of the turns/inch, which is verified with the math on the site and video.
Thanks for noticing.
Employment motivation: fun and happiness, not money!
Video build log: http://www.buildyourcnc.com
Old 01-12-2010, 06:57 PM
jtluttrell's Avatar
See the last paragraph at the very bottom of the page here:
http://buildyourcnc.com/leadscrews.aspx
And again, I just want to clear this up for the next guy. phooddaniel's sight is a great source of information. Keep up the good work.
Old 01-12-2010, 07:07 PM
With the way that last paragraph is formed, I may have been describing number of starts (in my mind) and not turns/inch. If you have the same tpi, but the number of starts is increased, the precision is actually reduced.
Thanks for the kind remarks. I greatly appreciate it!
Steps per Inch / mm themonster Linear and Rotary Motion 1 08-25-2008 08:08 AM
Procedures to calculate steps per inch DrStein99 LinuxCNC (formerly EMC2) 5 08-17-2008 07:53 AM
steps per inch Chris Tucker Linear and Rotary Motion 12 08-14-2008 07:50 AM
Set-up / Steps per Unit / Threads per Inch adda Mastercam 2 01-15-2007 04:29 PM
Steps per inch formula, What I am doing wrong? Noah Gecko Drives 13 05-27-2004 06:56 PM
