| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| the z carriage plate looks to be about in-line with the front bearings of the long-axis carriage, putting the centre of mass on the plasma head outside the centre of support area. On woodworking designs the router is usually within the footprint of the long-axis carriage. Would this cause a twisting moment for a plasma head? How would you do the final adjustments to take the play out of the carriage/rail systems? |
| LaserImage: I attached a pic adding a support table. Sam: What's seems to be the problem for you. Thanks for any comment. Paul: Plasma cutter is usually offset from the carriage axis (load is not an issue I believe). The idea is using steel profiles and ordinary rollers for the whole system. Now, I'm not sure about precision/accuracy even for "rough" plasma cutting. |
| Hi ABEngine How big is your machine going to be, as long as you have lots of the angle supports you should not have any problems, just don't weld the angle support brackets Screw/bolt them as they will bend your rails Good job, you have found another way to use the skate type bearings
__________________ Mactec54 |
| I glanced at it too quickly and made an assumption based on that quick glance. Gary |
#11
| Good Ideal But check the one I just built It may give you some more ideals I will try to post pics later if I can but here is the link to the pictures Trell http://www.ecosee.com/picturesnow@ec...ter/index.html |
#12
| Thanks for all comments. I plan to build a 4'X8' plasma table. Maybe 1" square is enough as the two can be linked in the middle by bolted angles. The idea is to avoid welding as much as possible. I use Inventor for drawing. AB |
| Newbie- Best Homemade Linear Motion Mechanism? | mitch_1 | DIY-CNC Router Table Machines | 3 | 10-22-2009 08:42 PM |
| Homemade Linear Slide System | midiguy732 | Open Source CNC Machine Designs | 15 | 02-02-2009 07:03 PM |
| homemade linear bearings for a 48"x96" router | luther | DIY-CNC Router Table Machines | 6 | 06-27-2007 10:08 PM |
| My homemade linear bearings: yes or no? | tybrenis | Linear and Rotary Motion | 25 | 01-06-2007 02:16 PM |
| Homemade Linear Design, Feedback. | MrBean | Linear and Rotary Motion | 22 | 05-20-2005 02:50 AM |
