Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-30-2009, 04:44 AM
IZen is on a distinguished road
Question 16mm open linear bushings on 5/8" rails.
Hi Everyone.
I was wondering if anybody can tell me how flexible these 16mm open linear bearing bushings from VXB might be:
http://www.vxb.com/Merchant2/merchan...t_Code=Kit7443
I'm hoping I could squeeze them a bit to reduce the diameter to 15.875mm to fit the four supported 5/8" rails I just scrounged from scrapped plotters.
My blocks would be designed to vary the clamping pressure around the bushings.
The price difference for 16mm vs 5/8" is $7.95 USD compared to $21.95 USD each and I'm thinking, I might use 12 pieces if I can score more rails, so the savings is big.
The free rails are 56" long and, along with the garage opener screw drive sections I also picked up for free, will probably dictate my design. My machines main function will be milling wood and it looks like the design will be a 4'x4' addressable area.
I can't afford the 5/8" linear bearings right now. If the 16mm won't work I'll build a skate bearing truck system until I can upgrade but it would be sweet to start out solid from the start.
Any observations on this type of bearing or any other advice would be greatly appreciated. I also have some ~175oz-in steppers to start off with and I just started building the drivers.
Thanks,
IZen
Old 12-30-2009, 07:12 AM
ger21's Avatar
Set aside $10 a week and start designing and building. In two months, you can buy the 5/8" bearings. I don't think anyone will tell you that the 16mm will work, although they might. But if you try it and they don't work, you'll have spent a lot more.
Old 12-30-2009, 01:05 PM
Thanks for the advice Gerry. That's what I expected to get back, but I'm looking for some real world observations.
I had enough trouble justifying the cost of driver ICs to my "funds manager." This is supposed to be a "no-cost" scrap built machine, constructed during a break in employment. The $264 for twelve 5/8" bushings won't be in the budget until I can show results.
What I was considering was spending $38 with shipping for 4 bearings. I can build a test gantry around them and measure any slop and deflection before finalizing my design. If they turn out not to work, I have some 16mm rods I might use on my Z, so they can be reused if I don't ruin them.
The following calculations are simplified by ignoring clearance:
The difference in diameter is .125mm or 5 thousandths of an inch. In relative terms this means that I would have to reduce the diameter by 0.8%.
Others have commented on the need to support these type of bearings from opening up under load. If they are indeed this flexible I have no doubt I could sufficiently constrict them.
What I don't know is if the resulting constriction to the ball races will bind them. The interior circumference will also be decreased by about .8% which is 0.393mm. In the worst case scenario where all of the deformation occurs at the three races each race gap would shrink by ~.131mm. This is just over 5 thousandths and may be too much.
I cant find the spec for ball size or clearances so I can't calculate the relative amount of pinching.
I'm probably going to try it out. I'll have to do some initial measurements and tests on the shorter 16mm rails so I can compare the rolling resistance. As long as they don't bind and wear my rod I think they might be OK for now.
-Scott
Old 12-30-2009, 02:31 PM
mactec54 is on a distinguished road
Hi IZen
The .0049 may close up ok but these bearings are loose to start with so you may need to start with a bore .008 smaller in your mount & just keep boring out a little untill you get the right fit, now this will only work with the open bearings & not the closed
Mactec54
65" linear rails zigmart EBAY ADS 0 08-24-2009 07:31 PM
Question on linear bushings and rails Dman65 Linear and Rotary Motion 4 07-29-2009 07:27 PM
16mm vs. 20mm supported linear rails... WilliamD DIY-CNC Router Table Machines 4 12-19-2008 05:37 PM
1.5" unsupported linear rails. magick_man Linear and Rotary Motion 7 01-11-2008 11:11 PM
1" Linear Bearings (open) jdbaker Linear and Rotary Motion 7 10-20-2005 12:22 AM
