Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 12-07-2009, 08:23 PM
lgalla's Avatar
lgalla is on a distinguished road
THK blocks and rails
I have purchased various used THK blocks and rails on E-Bay and been worried if they are toast.I have THK-21 and THK-27'S smooth as silk.They move under their own weight.I purchased 3,THK HSR20R2CIME 44"rails and blocks NIB and they are very tight and actually feel like they bump and grind.
Possibly they have a heavy pre-load?Any how I suppose it is difficult to determine if your used blocks are good by how they feel.
I just went back to slide the blocks and wow you would swear they are toast.
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
Old 12-11-2009, 09:14 PM
ksanalytical is on a distinguished road
Larry,
I have several barely used THK rails and bought brand new truck direct from THK. None of them move under their own weight. They're pretty smooth other than that though. These are mild preload trucks. Very easy to slide on the end of the rail. I'd worry more about the loose ones.
Ken
Old 12-12-2009, 07:09 AM
The Blight's Avatar
The Blight is on a distinguished road
I have 2 THK SNS45 rails with trucks, and it takes a fair amount of force to move them, but these are heavy preload trucks, so that might explain it, but I don't feel any bumping or grinding in these. Are these caged ball trucks? Can you remove them from the rail without losing the balls?
IKO linear blocks, no rails isvflorin EBAY ADS 0 10-17-2009 02:29 AM
Help with THK rails & blocks (mismatch?) daemonfly Linear and Rotary Motion 6 03-06-2009 07:31 AM
Need Help!- Where to get Linear rails and blocks? gunlocators DIY-CNC Router Table Machines 3 08-09-2008 08:55 AM
hiwin guide blocks and rails eloid Linear and Rotary Motion 5 12-10-2007 05:46 AM
What size THK/Hiwin rails and blocks? Zumba Linear and Rotary Motion 8 08-24-2006 11:10 PM
