Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 11-29-2009, 07:54 PM
Chuck_M is on a distinguished road
Question CnC Plasma Cutting Table - Rails and Drives
I am in the process of designing my own CnC Plasma Cutting Table, starting with a 4x4 table that could be expanded to 4x8'. For a small shop table aimed at general cutting and some art work, is it worth going to Linear rails vs. V-Bearing Rollers and Rails, and also Ball Screws over rack and pinion.
Initial estimates of the 4x4' table (ex. controls/motors) at ~$2,500 with v-bearing and rack/pinion. The linear rails and ball screws could add an additional $1,000 - $1,500.
Old 12-05-2009, 09:10 PM
bthomps5's Avatar
bthomps5 is on a distinguished road
i am running polybelts 25-5M Polyurethane with Steel Cords getting 2500 ipm rapid, 600 ipm cutting speeds well fast as plasma can burn, very quiet very smooth and very accurate, 30 inch pound servos,4:1 belt reduction very smooth cuts no slag ,belts are 4.99 foot fairly cheap 60 feet will build a nice 4 x 10 table
Old 12-09-2009, 11:47 AM
Dirtbos is on a distinguished road
Buid log?
Did you post a build log for your table?
Also, what is the name of the supplier for the steel cord belts?
Old 12-18-2009, 06:44 AM
bthomps5's Avatar
Smile sorry about the delay
polytech design http://www.polytechdesign.com/ thatis where i bought belts and pullys very nice belts
My CNC Plasma Cutting Table DZstar CNC Plasma and Waterjet Machines 86 01-17-2012 02:04 AM
Newbie- Plasma table, motors, drives, controllers Lambo429 Plasma, EDM and other similar machine Project Log 3 01-22-2009 10:53 AM
Plasma Table Timing Belt Linear Drives Richard Honey CNC Plasma and Waterjet Machines 1 10-04-2007 02:47 PM
Design of plasma table, high rails or low rails? Apples CNC Plasma and Waterjet Machines 3 12-18-2006 02:21 PM
6.5m X 2.5m CNC plasma cutting table rugludallur CNC Plasma and Waterjet Machines 3 11-16-2006 12:53 AM
