Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 11-23-2009, 06:33 PM
lgalla's Avatar
lgalla is on a distinguished road
rail cutting
How would THK type rail be cut and machined for butt joints.Should a pin be used?I am not thinking of doing it myself,but would like to know how it is done and be educated in the process when approaching a machine shop.
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
Old 11-23-2009, 09:21 PM
electronicwood is on a distinguished road
I joined three sections on THK-type rail for my router. I needed a pair of rails 7.5' long each and did not have the budget for one-piece rails. I set three sections of rail in a groove machined into a 7.5' long piece on aluminum and bolted them in place. I made the groove in the aluminum by placing two locators on the mill bed and sliding the aluminum along these locators for each cut. I took a little effort to get the locators parallel to the direction of mill travel, but it worked pretty well.
When I first bolted the three sections of rail in place, the bearing truck would not travel across the joint. I then had to unbolt the rails and lap the bottom of the groove in the aluminum until the bearing travel was smooth. This took several iterations of assemble-test-disassemble-lap-repeat, but I was able to get it done in one evening.
I'm not going to claim this is the best way to get a long bearing, but it does work.
cutting hardened guideway rail eloid DIY-CNC Router Table Machines 4 12-11-2007 11:53 PM
Cutting hardened Thompson Rail. pbunnstf General Metalwork Discussion 5 07-09-2007 07:19 PM
One Z Rail? lgalla Linear and Rotary Motion 34 03-03-2007 10:06 PM
rail selection (forces involved in cutting) daedalus Linear and Rotary Motion 1 11-17-2005 09:30 AM
Wrong THK rail - Help! samualt DIY-CNC Router Table Machines 10 07-17-2004 01:26 PM
