| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
#25
| Hay Mariss,thanks for dropping by.I thought this thread would just be a re-hash of previous subjects. "Stepper missing steps"I this a general excuse for poor motor sizing?Does Mach3 say"Hay bud you missed some steps"?The software as I understand tells the stepper where to go but there is no feedback to confirm position.I would assume servos have the same problem.12'Oclock here must sleep on it Larry
__________________ L GALILEO THE EPOXY SURFACE PLATE IS FLAT |
#26
Yes. It is possible that you could miss steps due to electrical noise or other electronic issues. But, if the motors are sized properly, it should never lose steps. If you want to cut at 400 ipm, and the machine can only do 390 reliably, then you'll lose steps trying to cut at 400ipm. Thousands of people use stepper machines and never lose steps. If you read through all the build logs here, I think you'll see that the only time people mention lost step issues, is when they are first setting up their machines. Yep, same thing with servos, as Mach3 sends the same signals, and doesn't know if you're using steppers or servos. With servo's, though, The drives will fault if they lose position. You can wire the drives together so that if one drive faults, it'll stop them all.
#27
And you know that the servo motor, driver system switches from constant torque to constant power when the driver runs out of voltage head room just like a stepper system. And that a servo can be high torque, low speed or high speed, low torque depending on what you pick for voltage and current constants when you spec out the system. Just that hobby builders tend to take what they can get for as little money as possible. |
#28
![]() A ball screw can be thought of as a class one lever where the load and effort is either side of the fulcrum (B.S. centre). The load is pitch and the diameter effort. So just like a lever, you can decrease the effort by lengthening the input lever (increase dia.), or shorten the load side length (decrease pitch). Al.
#29
| It's very true that continuous torque of servo is relatively low compared to same size steppers. However, one should notice that servo motor has about equivalent PEAK torque than similar size & price stepper. In CNC one can size servo motors using peak torques because the load is highly varying and most of the time low torque is enough. Peak torques may be used during very fast accelerations and when milling tool enters in material. Some day closed loop steppers may become the winning choice (low cost drives needed). |
#30
| Found some useful formulae. For RPM of a screw.IPMxTPI.Say you want a feed rate of 200IPM and have a screw with 5TPI.200x5=1000RPM.Then go to Nook critical speed calculator and select the correct diameter screw. BTW is threads per inch the same as turns per inch? On motor size required. Watts=IPMxweight you want to move divided by 531.If you want to move say a gantry of 500Lbs at 200IPM....500x200/531=188Watts.Really?Does not look like a big motor to move that mass.Is my math correct?Perhaps I mis placed a decimal. Motor watts =VoltsXconstant current.I will chose a Keling DC servo.model KL-34-180-90 90Vx7.8Amps=702Watts Are these calculations correct? Larry
#31
Same. There is inertia to consider, the industry recommendation is not to exceed motor to load inertia ratio of 10:1. The inertia ratio decreases by the square of any reduction. If you download the Kollmorgen s/w from the Electromate site, it is a graphical sizing program that will give you an idea as to how inertia (acceleration/deceleration) affects motor sizing. Al.
#32
| Hi all, The math looks OK, and that motor would do even more work than you think, since the calc. is for power to LIFT the weight you're talking about! !! BUT WITHOUT LOSSES!! Also, and this is the big BUT, it takes no account of acceleration, which needs to allow for rotating bits as well as carriages etc. My builds aren't even started yet, but I picked up some sweet ballscrews, thinking "what'll do a lot'll do a little!" so 32x5 looked great, (and cheap!) My own education as to inertia of rotating masses is way past sell-by, so I tried dusting it off, and got seriously scary answers!! If memory serves, the radius of gyration of a cylinder, for estimating purposes, is approx 2/3 R. This means the mass of the screw (as above) is rotating at over 12 times the linear speed of the driven piece!! No problem once you've got there, but not to be ignored. Now, like I said, this is from a very distant education, and I'd welcome correction if it's wrong. Any comments about an unnatural fondness for hefty screws discreetly please! Regards, John |
#33
| John I only have 2 THK ballscrews for a dual Z.One is 2005 and the outher 1605 C-3.Never the less they are fine pices of machineing.I am kind of partial to the BK-15's larry
#34
| here is a stupid question ![]() Can a servo drive be used as a stepper drive?Or vise versa. The reason I ask is many beginners are shy of servos and some posters say to begin with steppers and up grade later.If a drive was dual purpose only the motors would be changed.Sorry for the stupid questions. ![]() Larry
#35
Thanks posters.I would have used the wrong ballscrews motors exc.My cutting speed would have been 200ipm before whip.Any ideas for a device to reduce whip on long screws?I attached a poor sketchup drawing. The idea is 2 spring loaded nylon pulleys.The nut would push the pulleys down while passing.This would reduce whip an allow higher RPM.Is it a good idea? Larry
#36
| Hi Larry, Have you considered the rotating nut type ball screws? Might be a nice way to avoid the inertia of an enormous ballscrew, while keeping the zero backlash advantages. You need a timing belt drive or something similar to drive the nut, which would also allow you to integrate the reduction you'll probably need from the servo. Best regards, Jason |
| Stepper or Servos? | gavztheouch | DIY-CNC Router Table Machines | 4 | 05-28-2009 01:02 PM |
| thread outlining ballscrew/rails/accuracy etc? | blau_schuh | DIY-CNC Router Table Machines | 3 | 12-30-2006 12:44 PM |
| Servos or stepper | freak_brain | Servo Motors and Drives | 17 | 02-06-2006 03:03 PM |
| strange bearing preload thread on ballscrew | mxpro32 | Benchtop Machines | 14 | 03-22-2005 01:23 PM |
| Servos on x/y - Stepper on z - will it work? | WoodSnarfer | Servo Motors and Drives | 8 | 11-16-2004 06:12 PM |
