Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 11-12-2009, 01:54 PM
Katoom is on a distinguished road
Bad Ball Screw?
We have a Makino FNC74.The Z axis is giving us problems.When machining
apart,the "Z" will go .012 deeper than it should.The read out reads the currect number,but the part is out of spec.
We used a dial indicator to check for this problem.What we found was at
a slow feed rate the "Z" was dead on everytime.But when we increased the
feed rate,the issue with the .012 returned.The readout reads the same every single time.and it does not change as the "Z" comes down.So I know that the Ball screw is not turning.
I was told that this could be caused by a bad Ball Nut.That at a higher feed rate,the balls move slightly.but then relax causing the "Z" to come down.
Is this true,or am I over looking something?And is there a way to verify that the Ball Nut is bad? Thanks
Old 11-12-2009, 02:37 PM
Is the ball nut mounted securely? Have the mounting screws loosened? Just a thought.
Dick Z
DZASTR
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 12:15 PM
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 05:21 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 12:23 PM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 09:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 01:10 AM
