Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
View Poll Results: If zero-backlash double ballnuts were available at the same price as two single nuts:
I would use the double ballnuts 16 84.21%
I would use the single ballnuts 2 10.53%
I would use both 1 5.26%
Voters: 19. You may not vote on this poll
Old 11-09-2009, 02:21 PM
*Registered User*
Glacern is on a distinguished road
Arrow GMT Ballscrews + Poll: Double vs. Single Nuts
We'll be introducing a line of rolled ballscrews in the near future as well as other linear motion components.
The ballscrews will be rated C7, and will be polished for smooth motion. The ballnuts are sealed with internal return tubes. They will be available in 20mm (12, 18, 24, and 36" lengths) and 25mm (48, 60, and 72" lengths).
The ends will be pre-machined to fit BK/BF and FK/FF style support blocks with 15mm and 17mm ID 72XX and 62XX bearings (which we will also offer).
For ease of installation, we'll have zero-backlash double ballnuts available for the same price or less than what one would normally pay for two single ballnuts (in the $100-$140 range). Would anyone here still be interested in single ballnuts?
-Sol
Glacern Machine Tools
A sample 25mm GMT ballscrew with single and double ballnuts.
Old 11-11-2009, 10:43 AM
wildwestpat is on a distinguished road
Are you not asking the wrong question to get a market potential difference between single and double nuts if both are zero backlash? The physical size of the unit - in service life - backlash control with service life - ridgidity - inherent accuracy - are all factors that have to be reconciled with cost when purchasing ball nuts.
Your straw poll has a statistical skew as it mixes the retro / repair market and the new design demand.
Regards
Pat
Old 11-29-2009, 01:27 AM
asuratman is on a distinguished road
Hello Glacern,
When will those ballscrew be available? Thanks.
Old 12-03-2009, 11:11 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
You gotta love the way the orange plugs on the ballnuts are color coordinated with the Glacern logo!
I too will be curious when they are available to check them out. Need to set my lathe up on ballscrews one of these days.
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 12-05-2009, 12:15 PM
Hans_G is on a distinguished road
Those look just like the ballnuts I received from LinearMotionBearings on ebay.
Tags
ballnut, ballscrew, glacern, gmt
cheap sources of blank copper clad single or double sided PCBs? subatomic PCB milling 7 06-03-2009 09:26 PM
Newbie- single or double shaft? forgetcolor Stepper Motors and Drives 5 05-21-2009 08:28 AM
Supplier for ballscrews,nuts for Zay conversion davo727 Benchtop Machines 10 01-31-2007 07:20 PM
Y axis rail- single or double? Corvus corax Linear and Rotary Motion 5 11-15-2005 07:42 PM
Thoughts on single or double screws. LeeWay DIY-CNC Router Table Machines 5 02-17-2005 01:00 PM
