Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 10-16-2009, 07:18 AM
nearbeer is on a distinguished road
vendor of extra long stroke dampener for material handling
To all:
I work for a company that caters to the material handling industry. A distributor has approached us looking to design a cart to move a heavy load vertically (down) using gravity only. I am looking to source extra long shock absorbers or dampeners that will allow this to happen. Specifically, I am looking to move the cart 72" and it will carry a load of 2500#. Powered hydraulics and pneumatics are not an option; the unit must be self contained.
/R,
NearBeer
Old 10-17-2009, 11:12 AM
Hydraulic cylinder to air over oil cylinder. Size the cylinder to compression load of ??? psi.
I use this as counterbalance mechanism.
You can use line air supply or use captive air or gas. Like nitrogen charged shocks or similar to the cylinders that support many hatcheback lids.
Dick Z
DZASTR
Material Handling on BIgger Machines standles CNC Plasma and Waterjet Machines 14 01-21-2010 08:21 AM
Material handling robots? REVCAM_Bob CNCzone Club House 1 10-13-2009 04:10 PM
Extra Material Removal...Help Cartierusm ArtCam Pro 16 07-31-2008 06:56 PM
Extra long router bits for foam xshaper Product Announcements & Manufacturer News 0 10-14-2007 12:45 AM
Extra long router bits whiteriver General Material Machining Solutions 11 06-06-2005 03:21 PM
