Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 10-13-2009, 03:41 PM
Ferrari2007 is on a distinguished road
Ball Screw Newbie Question
Hi All,
I have what is most likely a dumb question, but here goes....
Building a CNC router and when I installed the ball nut for the Y axis and rotated it along the ballscrew, several of the ball bearings fallout the front (flange side) of the ball nut. Is this normal or will my mating flange provide the means to keep the ball bearing in?
When I did the same setup for the X axis I have not encountered the problem, it rotates fine and does not lose any bearings. Was I just lucky on the X axis or do I have a problem with the Y axis nut?
Both ball screws are identical as well as the ball nuts.
Old 10-13-2009, 04:07 PM
Posting a picture of my setup.
Once again I am sure I am overlooking the obvious, but appreciate any input.
THanks
Old 10-13-2009, 05:51 PM
*Registered User*
Glacern is on a distinguished road
The balls should not have fallen out of the nut. Sounds like something may have gone wrong during the installation, and some of the balls slipped past the return tube.
What kind of a ballnut are you using? External circulation with a bolt-on return tube, or internal circulation?
If you need a place to upload photos, you can try our free photo upload: http://www.glacern.net
-Sol
Glacern Machine Tools
Old 10-13-2009, 08:33 PM
Sol,
Thank you for your response and use of the upload site.
I am using a Thompson 1" round ball nut with external return tubes. Picture link is below
http://www.glacern.net/free_photo_upload/P1010005.JPG
Is there a seal that keeps these in that could have been damaged during installation? These are brand new and as I did on the X axis, I slid the ball nut on the screw while removing the cardboard tube as it threaded on...seemed pretty mistake proof, but it sounds like something went wrong like you said.
Thanks again
Kevin
Old 10-13-2009, 11:32 PM
*Registered User*
Hey Kevin,
There is no seal, just the cardboard tube, which may have slipped during installation.
Rebuilding the nut should be fairly straightforward, albeit a bit tedious, especially since you have two ball circuits. There's a step-by-step on how to rebuild these types of nuts somewhere on the web. I don't have the URL anymore, but perhaps someone else here does.
-Sol
Old 10-14-2009, 08:14 AM
Hi Sol,
I will search around for the rebuilding article on these and see if I can't get them reloaded properly. Its good to know that nothing is damaged, just sounds like I may have started off wrong during the installation.
Thanks again for the help.
Kevin
Ball screw question from a new guy! ben_kapitan CNCzone Club House 2 04-18-2009 10:19 PM
Ball screw Question rodzilla Linear and Rotary Motion 3 03-02-2007 04:16 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
Ball Screw Mounting Question. Willyb General Metal Working Machines 11 01-18-2005 12:02 PM
Ball Screw Question jjwl89 DIY-CNC Router Table Machines 13 07-20-2004 07:12 AM
