Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 09-25-2009, 07:13 PM
DanOSB is on a distinguished road
at5 25 wide timing belt tension?
im wondering if any of you know what tension the at5 25mm wide timing belt should be set at and how do you check if its set correctly? using those tensioner tester? is there a cheap verison of that stuff?
Dan
Old 09-26-2009, 08:40 AM
Try Gates' online engineering tech pdf.
Dick Z
DZASTR
Old 09-26-2009, 10:20 AM
url for that? i did email brecoflex (where i got my belt from) to get more info
Old 09-27-2009, 11:45 AM
Try these: www.gates.com/drivedesign
http://www.epi-eng.com/rotorway.../r...elt_issues.htm
Might have to mess around a bit, "google" the epi thing.
Dick Z
DZASTR
BMC20 Belt tension for servo drive? RoundieLand HURCO 1 05-08-2009 02:46 PM
Belt Tension Options?? flash319 DIY-CNC Router Table Machines 5 09-19-2007 02:06 PM
Timing belt tension requirements vs backlash jensor Mechanical Calculations/Engineering Design 1 05-20-2007 02:04 PM
Belt Tension Adjuster Design mxtras Mechanical Calculations/Engineering Design 8 05-16-2005 10:33 AM
