Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 09-19-2009, 09:08 AM
joprinz is on a distinguished road
Lightbulb 9' x 5' CNC Router Rack and Pinion Question
I am designing a 9' x 5' CNC Router. I read in many posts here about the need for a support in case of ball screws longer than 5 Feet. Considering my design requires an axis which is 9 Feet long I'm considering using Rack and Pinion instead. However I am finding it hard to pick the right Racks and Pinions.
Here is my Machine Specs:
X-Axis : 5'
Y Axis : 9'
Gantry Type : Moving Gantry
Gantry weight : 75 Kg
Max speed of Axis Movement : 120 ipm
Each Axis using Two 15mm Linear Guides and 4 Carriages
I have come up with the following rack and pinion from Gudel.
I was wondering if the above rack and pinion is sufficient for my design.
The above Pinion has 20 Teeth. Can using a 30 Teeth Pinion help reduce vibrations at higher speeds?
Also can someone suggest commonly used rack and Pinion Specs when building longer axis machines?
Please Advice,
Thank You.
Joe
Old 09-19-2009, 12:12 PM
ger21's Avatar
Imo, you should be designing for at least 500ipm. 120 ipm will be painfully slow with a 9ft axis.
Old 09-19-2009, 12:43 PM
Thank you Gerry, for your suggestion. I am new into building bigger units like this one. I had built a 2' x 2' router and a 15" x 12" Mill earlier.You are right... with 120 ipm It will probably take about a Minute to jog from one end to another. Point Taken
Has anyone used 1.5 Module Racks with 20 teeth Pinions in their CNC Routers? Plz share your ideas regarding the gearing requirements for a 20 tooth 1.5 Module Pinion.
Joe
Old 11-07-2009, 04:31 PM
blazedforever is on a distinguished road
can someone explain what the modul measurement is?
Old 01-16-2010, 11:27 AM
1000IPM is on a distinguished road
This would work for what you are doing -
http://automotioncomponents.co.uk/se...pinion&x=0&y=0
Old 01-16-2010, 11:44 AM
Those roller rack & pinion systems are quite expensive. But, Gudel R&P systems are pricey as well.
You may consider mounting either system rack teeth side facing down to avoid fouling the rack teeth. Just a thought.
Dick Z
DZASTR
Old 01-16-2010, 12:13 PM
Al_The_Man's Avatar
For a 110ft oxy/gas gantry I used Kohara products, these were supplied in Canada by Stock Drive Products. http://www.cadenas.de/catalog_pdf/khk.pdf
I used the SRF machine ground style of rack, these have countersunk mounting holes and machined ends for accurate butting up if required.
I installed the rack facing down and 28 tooth gear.
Gear SS2-28 and rack SRFD2-1500 (1,5metres/length).
CNC Router Parts Rack and Pinion Development ahren DIY-CNC Router Table Machines 294 06-29-2011 09:45 PM
stepper for router (direct rack&pinion ?) student1616 Stepper Motors and Drives 4 03-10-2009 01:22 PM
Rack and Pinion question scrambled Linear and Rotary Motion 7 04-24-2008 11:24 AM
rack and pinion question eloid DIY-CNC Router Table Machines 6 10-29-2007 07:27 PM
rack and pinion cnc router eloid CNC Wood Router Project Log 3 02-27-2007 02:19 PM
