| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Does anyone know of a source for ground ball screws at good prices? I contacted Hiwin and they really don't carry off the shelf ground ball screws mostly rolled. The off the shelf type screw is for bridgeports which could work...thay said about $500 for 32" and under with nut. Thanks John |
| Why do you need a ground screw? Not a lot of companies stock ground screws, and if you do find one, you will pay through the nose for it.
__________________ Zapp Automation Ltd www.slidesandballscrews.com |
| John, Companies like Hiwin grind their screws on very expensive Mitsui Seiki grinders, specifically designed for manufacturing ballscrews. It's a slow process, so they only grind as much thread as needed (specified by the customer). Sometimes a customer may need a 45" shaft but only 30" of threads, and thus save money by paying for the equivalent of a 30" ballscrew. Plus, most customers of ground screws want to purchase them ready to install with very accurately ground bearing journals in place. It wouldn't be cost effective to grind long sections and chop them up as they do with rolled screws. There's just too much wasted thread from the cutoffs and the bearing journals. In addition, long sections of thread require long travel grinders, which are few in number and much more expensive. Automation4less.com sells NSK ballscrews in various diameters, pitches, and lengths. They might have what you want. Accuracy is C5, 0.0005" max lead error per 300mm. A lot of them are probably good enough to pass for C3, 0.00027" max lead error (detailed inspection reports are provided with each screw), but are still only rated for C5, since I don't think they offer C3 screws as off-the-shelf products. |
| I apoligize for resurrecting an ancient thread. Ground screws are not too difficult to come by. We stock thousands of ther ourselves over here at WInter Engineering. Any questions, pm me. Dave www.winterengineering.com |
| Ball Screw Source for Conversion | RTP_Burnsville | Linear and Rotary Motion | 10 | 12-30-2006 04:39 PM |
| Buying Ground ball Screws | Burn | Linear and Rotary Motion | 9 | 09-06-2006 09:05 AM |
| Precision Ground Ball Screws | Builder | Bridgeport and Hardinge Mills | 2 | 10-31-2005 12:18 PM |
| Anyone looking for a Precision ground ball screw... | Dave's_Not_Here | Linear and Rotary Motion | 3 | 06-23-2005 09:33 AM |
| Rolled or Ground ball screws | Mr.Chips | DIY-CNC Router Table Machines | 15 | 12-21-2004 09:11 PM |
