Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-27-2009, 11:17 PM
parkerbender is on a distinguished road
Engineering project help...
I'm working on a steering system for a 1/4 scale tractor that is electronically controlled. I'm trying to put together a new system that auto-centers, using a linear actuator. The question is how does a person make a controller for let's say a nook 8" linear actuator, that goes back to center without an input? Would the easiest way be to use an actuator with a built-in potentiometer, and a voltage comparator? The tractor is being used for exhibition purposes by the University of Nebraska - Lincoln.
Ideas? Opinions? Thanks for anything!
-Parker Bender
Old 08-27-2009, 11:37 PM
Trucks is on a distinguished road
Just out of curiosity what will be making it go back to center? Is it following something, or is the purpose just to make it center after it has been moved?
Old 08-27-2009, 11:43 PM
well, the tractor is currently steered with a joystick, and a dpdt switch that is normally open in the center, i'd like to make the steering go back to center when it's open, so the tractor would turn, then when you put the control back to center, the tractor would straighten out, instead of having to turn it the opposite direction to balance it out.
WE-SIM by Whittlock Engineering millman52 CNC Plasma and Waterjet Machines 4 02-09-2012 03:40 PM
Looking For A Job- looking for a job related to engineering galaxyman7 Employment Opportunity 0 08-26-2009 05:25 PM
Engineering and Design RhinoForm Employment Opportunity 0 11-25-2008 09:05 AM
Help with reverse engineering randycasey Solidworks 5 10-06-2008 05:56 PM
engineering basics inthedark CNCzone Club House 13 03-27-2004 03:21 PM
