Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-24-2009, 11:12 PM
Crawler374 is on a distinguished road
Need help identifying the linear bearings please.
Hey guys, another question form the newbie
I was surfin ebay just looking at CNC stuff. I came across some linear bearings that has 6min left, and I won the bid for $11.50+$30.35 for shipping. $42 isn't bat for 6 linear bearings!
My problem, is that i got ahead of myself without checking the quality, the size, or the strength they can handle. I ordered the IKO linear bearings.
IKO LWH30C1BT2HS2 Linear bearing
ebay link: http://cgi.ebay.com/ws/eBayISAPI.dll...torefresh=true
I looked on IKO's website, but i couldin't find the size rod i will need to use these. Are all linear bearings use the same rod? do they vary? Are these bearings good? If anyone can point me in the right direction would be highly appreciated!
Old 08-24-2009, 11:21 PM
For the linear rails, does this sound right?
H=26mm
W=28mm
Old 08-25-2009, 10:23 AM
ger21's Avatar
They are probably 30mm rails, based on LWH30. If you can find cheap rails, that's a really good deal you got. Try this.
http://www.ikont.com/Catalogs/lwh.pdf
Linear Bearings 2muchstuff Linear and Rotary Motion 12 07-13-2008 02:24 PM
VXB linear bearings Mr.Nerd DIY-CNC Router Table Machines 22 08-05-2007 08:20 PM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 10:06 AM
linear bearings broncosis DIY-CNC Router Table Machines 0 06-10-2004 06:03 PM
Need help on linear bearings bbergami DIY-CNC Router Table Machines 11 05-25-2004 06:04 PM
