Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
  #85   Ban this user!
Old 12-04-2009, 10:48 AM
DAVINCHO is on a distinguished road
Thanks a lot,
Great article !!!!!
  #86   Ban this user!
Old 06-07-2010, 02:36 AM
R!f@@ is on a distinguished road
nice article
  #87   Ban this user!
Old 07-09-2010, 12:24 PM
kurniawan is on a distinguished road
hallo
hallo
  #88   Ban this user!
Old 12-30-2010, 06:15 AM
headsmess's Avatar
headsmess is on a distinguished road
phwoar! i read all that!
is that there "warner red label" a 2 start thread? me sees two return tubes and the pitch is waaaay steep for the depth.
which raises an interesting point...do the balls recirculate on the same track or keep crossing over in a multi start system?
  #89   Ban this user!
Old 01-02-2011, 05:22 PM
dustin1706's Avatar
dustin1706 is on a distinguished road
Great write up!
Thanks!
JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
Joes 4x4 R&P in progress
  #90   Ban this user!
Old 05-13-2011, 10:11 AM
beaker152 is on a distinguished road
newbie questions:
i note that many of the items on ebay are described as having "signs of cosmetic wear"... is it a false economy to buy used ball screws for precision CNC applications?
are there any nuts to stay away from with the THK ground ball screws? i've had a hard time correlating markings i see in the item images with listings in the THK catalog (THK KX 80376, for example).
are the differences between BIF, DIK, BTK, etc. important to the performance of the unit or is it just a different nuts/seals?
lastly, how much of the shaft needs to protrude from the fixed end for attaching to the motor?
thanks!
  #91   Ban this user!
Old 07-19-2011, 02:09 PM
louieatienza is on a distinguished road
Originally Posted by beaker152 View Post
newbie questions:
thanks!
BIF : Offset preload
DIK: Offset preload, slim design
DIR: Rotary nut
BNFN: Double nut preloaded
DKN: Doubel nut preloaded, slim design
BLW: Large lead (1x screw diameter), preloaded
BNF: Single ball race
BNT: Square nut
DK: Slim version of BNF
MDK: Miniature
BLK: Large elad, no preload
WGF: Super Lead (1.5x-3x screw diameter)
BLR: Large lead rotary nut
These are all precision ground ballscrws....
  #92   Ban this user!
Old 07-21-2011, 12:55 PM
Bear5k is on a distinguished road
DIR: Rotary nut
BNT: Square nut
MDK: Miniature
To add on: A couple of the screw models (e.g., BNT, IIRC) are available as both a rolled and as a ground screw. Just knowing the product line of the screw may not be enough to determine rolled vs. ground (and a seller may not know the difference).
  #93   Ban this user!
Old 07-21-2011, 02:29 PM
Yes true... You must do your homework as well. One seller even has videos on his auctions showing the ballscrews' movenment, which helps. Check Swede's first post here for pics; there's good info there. Look for package markings or markings on the nut that say C0, C1, C3, C5; good chance they're ground, though I saw some rolled ballscrews that claimed to have C5 accuracy. After looking at a few auctions, it should be pretty easy to determine which is which.
I've been fortunate to find ground ballscrews in their original packaging, still sealed, and I guess that's the best way to insure you're getting something that works right. Of course that's no guarantee and there's always a small risk involved with online purchasing. But the more you look, the better you get at spotting the good stuff. Particuarly with the THK stuff, the rolled ballscrew nuts look very sumilar to the ground ballscrew nuts..
  #94   Ban this user!
Old 09-06-2011, 04:28 PM
UserJ is on a distinguished road
OK I cant afford ground ballscrews....what's the next best thing?
Ive looked at the prices at they are way too steep for me at this time. Having a budget of about $300, Im looking for what would be the next best thing. Is it possible to find a ACME anti-backlash ballscrew with somewhere between C7-C5?
  #95   Ban this user!
Old 09-06-2011, 06:23 PM
mike_Kilroy is on a distinguished road
typo
u shud be able to get c7 with good rolled screw. depending on length, dia, etc, u may buy it for that price. list this info if u want more info.... pm me with the details if u want a quote from ballscrews.com (thomson or bs&a).
  #96   Ban this user!
Old 04-16-2012, 03:33 AM
harryn is on a distinguished road
Hi, I was under the impression that in order to obtain "zero backlash", it required a double nut. Nonetheless, I have seen a variety of ballscrews listed on automationoverstock that are single nut, double nut, and a range of screw specs from C2 to C7, all claiming "zero backlash" nuts.
1) Am I confusing ball screws with other types of screws that need a double nut for zero backlash ?
2) Surely, a C2 ballscrew has less backlash that a C7, even if they are both called out as zero backlash nut types ? I guess then it is a question of spec / price for new one, but in the NOS market, that gets distorted a bit.
3) I assume that the NSKs with "zero backlash" are better than the hiwins with an "anti backlash" nut ?
Harry
Supporting RanaTeckk.com and their Dashboard for MS Project promo code WRLNT-2
Ballscrew advise... Dave's_Not_Here Linear and Rotary Motion 10 06-14-2005 11:21 PM
Super simple preloaded ballscrew design - It Works! jimjovan Vertical Mill, Lathe Project Log 9 04-25-2005 11:02 AM
Usual cost to turn down end of a ballscrew? WoodSnarfer General Metalwork Discussion 14 02-10-2005 01:36 PM
Ground Ballscrew - No nut! Swede General Metal Working Machines 4 11-20-2004 02:42 PM
ballscrew repair and some general questions jimbo DIY-CNC Router Table Machines 11 09-27-2003 03:48 PM
