Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-13-2009, 06:22 PM
Yovav is on a distinguished road
Service life for linear guide
I need some advice, does anyone knows what is a good service time in hours for a linear guide? Does 1000 hours are good? 2000? 4000? Or maybe even more (although I don’t know how it's possible in high speed and medium load)
I am having difficulties determining the right service life, after all no machine axis work constantly even if the machine works 24/7
Old 08-13-2009, 07:19 PM
ger21's Avatar
It depends on the specific guide in question and the load it's carrying. You'll need to look at the manufacturers data to figure it out.
Old 08-13-2009, 09:30 PM
*Registered User*
Glacern is on a distinguished road
If you're able to find the manufacturer's specs on the linear guides you're using, try to locate the dynamic load rating. This value indicates the average load the guides will take for a rated life of 50km (or 100km, depending on the mfg) of travel.
If the load on a given linear guide is less than the dynamic rating, it will last longer than 50/100 km.
Done right, they should last a lot longer than 4000 hours.
Old 08-13-2009, 10:26 PM
I think I might found the problem, is 1 G acceleration is to high?
Old 08-16-2009, 03:21 PM
I did all the math, and did an excel file for all of it, in the file you can see the calculation for the HIWIN ball screw and rail for each axis, but I must be missing something, all the axis have a double rail configuration with two guides on each rail, and even so I barely reach 3500 hours (and that is after I reduce the load safety margin to a minimum) I added the file to the post, all the field that are marked yellow are input parameters, all the rest are calculation based on those parameter and HIWIN catalogs, in the ball screw section you can also see the motor calculation, which are very problematic, since even in 1:4 ratio I need 8 HP for Z and 20HP for Y
Please help! And will be forever in you debt
Yovav
Need Help!- Choise the right linear guide Cardedon DIY-CNC Router Table Machines 3 03-31-2008 01:56 AM
Fuse And Linear Guide Alex S.A General Metal Working Machines 0 03-18-2007 05:48 PM
Guide Blocks or Linear Shaft? mre1000 DIY-CNC Router Table Machines 2 11-21-2005 06:38 AM
Diameter of shaft for linear-guide Phantom DIY-CNC Router Table Machines 7 10-26-2005 10:11 AM
Support for linear guide wile_e Mechanical Calculations/Engineering Design 7 01-29-2005 05:30 PM
