Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 08-05-2009, 06:52 AM
Dman65 is on a distinguished road
Which Skate Bearing Design Is Better?
I am trying to decide between using the JGRO type of slide using the angle aluminum and running on pipe and the CNCRouterParts type using their carriage design and the cold rolled steel flat.
Does anyone have any input on this?
Thanks,
Darrell
Old 08-05-2009, 07:19 AM
LeeWay's Avatar
LeeWay is on a distinguished road
If the pipe design is supported, then I would say they may both be equal. The flat bar design is easy to implement and it pretty solid. I used something similar in my router.
It's nearly as strong as a mill. Stronger than some smaller ones.
Lee
Simple skate bearing design. Will it work? bdahmet Linear and Rotary Motion 25 07-25-2009 01:15 AM
Skate Bearing Blocks? thebluedirt Linear and Rotary Motion 12 02-08-2009 07:59 AM
Lifespan of a Skate Bearing. Miata2k DIY-CNC Router Table Machines 9 09-22-2006 12:53 PM
skate bearing design paul langwade DIY-CNC Router Table Machines 1 07-29-2006 07:56 PM
Skate Bearing Design coolman DIY-CNC Router Table Machines 11 05-20-2005 01:25 PM
