| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
How do they work? I see the offset hole, but how do they use that for adjustment? Can they be locked in place? I have an idea for linear rail type brackets but would need this type of bushing for adjustments. Are they pricey or can I make them. Have a mini lathe and milling machine. |
| The ones for dual V rollers have a rough surface that grabs when the wheels are bolted down. Sort of like a lock washer so they can't turn. To adjust them, you loosen the bolt and turn them with a wrench. Then tighten the bolt back up. You can't see the roughness in these pics, but I've bought these and they are like that. http://www.cadcamcadcam.com/eccentri...ovewheel2.aspx
| I propose to have a wheel made of Delrin (Acetal) with an appropriate center hole, without a bearing, that can be adjusted to promote tight free motion. Can these type of bushings be used without a ball bearing?. |
| I guess, as long as the wheels thickness is less than the length of the bushing, or else the bolt head or washer will keep the wheel from turning.
| HighTechSystem's eccentric cam | MechanoMan | Work Fixtures and Hold-Down Solutions | 4 | 04-04-2009 08:31 AM |
| An Eccentric Shaft | melt_fire | General Metalwork Discussion | 6 | 02-17-2009 10:39 PM |
| Looking to learn how to use eccentric bushings for v-wheels. | groomden | Linear and Rotary Motion | 5 | 12-11-2008 08:17 AM |
| Where to find offset or eccentric bushings? | Apples | Mechanical Calculations/Engineering Design | 2 | 11-23-2008 03:26 PM |
| Eccentric bolts | JerryFlyGuy | Mechanical Calculations/Engineering Design | 14 | 01-17-2007 10:01 PM |
