Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-29-2009, 10:13 AM
Dman65 is on a distinguished road
Question on linear bushings and rails
I am still in the research portion of putting together a design for my first router table. For my linear motion, one of the things I am looking at is the cylindrical rails with the cylindrical fittings that go all the way around or most of the way around in the case of the open design for supported rails.
The question I have, is what do you do with these bushings? Do you bore out a block of aluminum or something and then press them in or fit them with set screws? If this is the case, would HDPE be strong enough to use for that casing?
If that is not what you do with them, please enlighten me.
Old 07-29-2009, 10:23 AM
ger21's Avatar
I used plywood and held them in place with snap rings.
Old 07-29-2009, 04:49 PM
Thanks for the response Gary.
Do you happen to have a picture of how you did that?
Thanks,
Darrell
Old 07-29-2009, 05:07 PM
ger21's Avatar
Not any real clear ones, but how about this?
http://www.cnczone.com/forums/showpo...&postcount=117
Old 07-29-2009, 07:27 PM
Thanks Gary. That definitely gives me an idea.
Linear rails question... SatanKlawz DIY-CNC Router Table Machines 4 05-09-2009 04:45 PM
where to buy linear bushings? slat26 Linear and Rotary Motion 3 03-04-2008 12:34 PM
Question about Linear Rails Sizing bml6116 Linear and Rotary Motion 13 01-01-2008 09:03 PM
VXB linear bushings... WilliamD Linear and Rotary Motion 3 11-21-2005 04:11 PM
