| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
Hey I'm building a large XYZ router with 400 oz in Xylotex motors. Two motors will drive the main gantry, but in order to keep them tied together it's apparent some kind of belt system is needed so they can't move independently. Can someone please help me find some (hopefully economical) belt parts to fix on to the 1/2" 5 start 10 TPI shaft to keep them in sync? Thanks. |
In Mach3 (and I suspect other progs as well) it is possible to connect two steppers to drive the X-axes. Connect the first stepper to the normal X-axis output and the second to the A-output. Then you configure the prog to drive A as a slave to the X-axes. This way you wont have to use any belts or anything, the program will take care of driving both steppers in sync and your problem is solved. Good luck with your project! |
| they are connected and configured as slave axis. But they will still lose steps individually, I'm looking to lock them together mechanically because even though I plan on installing encoders onto them, that won't lock them together it will only stop the machine if they go out of sync. |
| Why not just run it slower so it doesn't lose steps? Even if they are linked together mechanically, they'll still lose steps and mess up your parts.
| pallet racking | blinton | Want To Buy...Need help! | 0 | 02-04-2009 10:22 AM |
| Racking... | Rob27 | DIY-CNC Router Table Machines | 2 | 11-09-2008 02:27 PM |
| Gantry Racking? | mike hide | Joes CNC Model 2006 | 7 | 06-17-2008 09:42 PM |
| Gantry Racking | DEW | Mechanical Calculations/Engineering Design | 4 | 08-12-2006 09:24 PM |
| Flex and Racking? | bearwen | DIY-CNC Router Table Machines | 3 | 03-07-2006 10:01 PM |
