Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 07-03-2009, 09:26 PM
oxford's Avatar
oxford is on a distinguished road
ballscrews vs e-gearing
I am building a gantry mill.
I have two actuators I want to run parallel for the x axis. The problem is that they both have different ballscrew pitches.
I have mach 3, so I have considered running one side as a slave and tweaking the motion to be equal with the motor tuning feature.
My other thought is to find a ballscrew and nut match.
My concern with e-gearing through Mach 3 is that under start-up and over time, missed steps will induce stress and problems.
My concern with matching pitches is cost.
Any thoughts?
Thanks.
Old 07-09-2009, 04:03 PM
oxford's Avatar
Leaning towards matching ballscrew pitch
How standard are the machined end sizes?
I had a website to the Taiyo actuators, but it gave me some problems
Old 07-09-2009, 06:11 PM
ger21's Avatar
When using slaving in Mach3, all settings for the two axis must be the same.
Old 07-09-2009, 08:46 PM
oxford's Avatar
So the motors would have the same tuning?
Which means if I use MAch3, I need to have the same pitch ballscrews.
:P
Old 07-09-2009, 08:49 PM
ger21's Avatar
Yes.
Old 07-09-2009, 11:08 PM
diycnc is on a distinguished road
i got my ball screws from china. they got here before the timing belts i ordered on the same day from the usa.. they will do any machining you need and will throw in stuff like motor couplers if you ask. very reasonably priced
cgxfred@yahoo.com.cn
Gearing ???? VSNT DIY-CNC Router Table Machines 17 08-31-2007 12:51 PM
gearing question again timmyb199 CNC Plasma and Waterjet Machines 15 09-30-2006 03:39 PM
Gearing down... snooper Mechanical Calculations/Engineering Design 9 08-02-2006 11:26 PM
Rack gearing? DennisCNC Linear and Rotary Motion 1 05-17-2006 09:36 PM
Need help on Gearing CAM_MAN DIY-CNC Router Table Machines 8 04-05-2006 12:23 PM
