Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-22-2009, 06:46 AM
satguy is on a distinguished road
Urgent question!!minimum pulley size and belt type?
Im just about to order a belt from stock drive.
Can someone please tell me if a rubber/neoprene belt with fiberglass reinforcement is suitable for a small XL sized 15 teeth pulley.
Pitch Dia. : 0.955" inch
Outside Dia: 0.935" inch
all the literature on pulleys and belts that i have read say that you cant use a small pulley since the fiberglass fibers break as they dont bend to well but they dont tell you the definition of small (how small??).
can someone please tell me if this belt will suit.
thank you
Old 06-22-2009, 08:05 AM
ger21's Avatar
Don't have time to look right now, but they list minimum recommended pulley sizes per belt pitch.
Need Help!- pulley bore size question satguy DIY-CNC Router Table Machines 3 06-16-2009 12:16 AM
Belt and pulley xshaper Foam Cutting Software 5 09-20-2008 06:46 PM
Belt size/spec for Sieg X3 driving belt rashid11 X3/SX3/G0619/G0463 0 02-10-2007 07:01 AM
RFQ V-Belt Pulley vadimvc Employment Opportunity 0 07-14-2006 01:10 AM
SDP-SI timing belt pulley question cnc2k Mechanical Calculations/Engineering Design 4 08-21-2005 02:17 AM
