Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-20-2009, 11:42 AM
SatanKlawz is on a distinguished road
Couple Acme lead screw questions...
I have a 60" acme screw that is going to run one of my axis. Being that it is only 1/2" in diameter I know that I am going to have to run the machine a bit slower or design it to turn the nut instead of the screw to prevent whip.
Where are the designs and parts list for making a setup that turns the nut instead of the screw?
Also my screw is made of steel and I have 2 different nut options (plastic and bronze) Which one of these should I go with? I do not want to wear out the screw as the nuts are much cheaper to replace so I was thinking of using the plastic nuts. What do you guys think and what do you lube acme thread with?
Acme lead screw 1.5 meter up osix Want To Buy...Need help! 0 04-16-2008 10:57 AM
Acme Lead Screw Questions Eurisko DIY-CNC Router Table Machines 4 03-26-2007 05:19 PM
acme lead screw swarfmacdaddy Linear and Rotary Motion 4 12-11-2005 07:09 AM
Acme Lead Screw Decision js15 DIY-CNC Router Table Machines 0 07-20-2005 02:44 PM
acme lead screw article sdwilson DIY-CNC Router Table Machines 1 12-14-2003 12:33 AM
