Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-16-2009, 04:46 PM
badassdevil is on a distinguished road
whip on lead screw
I am looking for some help i am trying to get rid of the whip on my z lead screw it is 1800 mm long and 12mm in diameter any ideas how i can lose the bad whip i am thinking of using m16 or m18 screw
Old 06-16-2009, 06:04 PM
diycnc is on a distinguished road
i would go with 25mm with 10mm lead minumum, it will still whip but at a higher rpm
look up on ebay LinearMotionBearings they have decnetly priced screws.
Old 06-16-2009, 06:09 PM
BillTodd is on a distinguished road
That's a serious Z axis
12mm seems a little light for a screw of that length it has a core of only about 10mm.
One option (other than increasing the diameter of the screw) is to re-engineer the axis so the screw is stationary and taut between mounts, while the nut rotates (i.e. the nut is mounted, with the drive motor, on the gantry)
Bill
Old 06-17-2009, 08:11 PM
Matt Adams is on a distinguished road
How fast do you want to spin, and what is the pitch of the screw?
The 25mm diameter screw with 10mm lead recommended above is rated for 362 inches per minute. Is that enough?
1" diameter with a 1/2" lead gets you up to 468 i.p.m.
Matt Adams - Motion Control Application Engineer
IMAC Motion Control - Elgin, IL
Old 06-19-2009, 12:27 PM
i got confused it should be the x axis lol funny considering i am a cnc machinist for a living
Old 06-19-2009, 12:29 PM
thanks for all the help guys i have re designed it so the nut rotates rather than the screw
Old 06-19-2009, 06:18 PM
Pictures - or it didn't happen....!
Bill
Old 06-20-2009, 06:58 AM
svenakela is on a distinguished road
Very good idea, I use rotating nuts myself and they are very well performing. I can "pre-tension" the screw and even though my screws are as long as yours (but thicker though, 16 and 20 mm) I have no problem driving my axis at 15-20 meters per minute, that's about 600-800 IPM.
Pictures not needed, I have videos.
Old 07-06-2009, 10:20 AM
peter.blais is on a distinguished road
Looks like this thread is sorted- FWIW though, all the big screw manufacturers provide equations for predicting whip in their data sheets. A quick run through of those would prevent nasty surprises, and could probably be *roughly* used with other no name brand screws as well, for hobby use.
Old 08-13-2009, 02:57 PM
screw whip
the system in your vids is very simular to mine and it works just great length is no longer and issue so in my opinion a better system
  #11   Ban this user!
Old 08-13-2009, 03:48 PM
Come on then, where are the pictures ?????
Bill
  #12   Ban this user!
Old 03-29-2010, 05:16 PM
jurban is on a distinguished road
Are there any commercial/stock rotating nut ball screws? The examples I've found here look custom or at least partially fabricated. I'd rather spend the money on that part instead of the time.
How do you mount a lead screw/lead nut? jbluetooth DIY-CNC Router Table Machines 2 12-01-2008 04:10 PM
lead screw whip ? bearing to use and why? technomage Linear and Rotary Motion 7 05-07-2007 06:16 PM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
Lead screw whip spalm DIY-CNC Router Table Machines 3 05-24-2005 02:04 PM
