Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-12-2009, 05:27 PM
Zaher is on a distinguished road
What Bolt's grade should be used in linear rail mounting?
Hi guys
Can I get a recommendation on the Bolt's grade should be used to mount HIWIN rails knowing that the bolt size specified in the manual is M5 and tightening torque 883 N-cm (or 90 Kgf-cm)
is Grade 12.9 suitable in this Case?
Old 06-13-2009, 12:24 AM
davereagan is on a distinguished road
12.9 is as strong as you can get commercially. Allen bolts are always the strongest grade. Stainless is what you want to stay away from. Weak, not even on the C scale for 18-8.
Old 06-13-2009, 01:55 AM
thanks davereagan
yes I am using Allen bolts but they are Stainless because I am using them in WaterJet Machines where rust may occur easily and I wasn't paying much attention before to the bolt's grade issue
do you have a better option instead of stainless bolts for WaterJet's rails ?
and do any one has experienced a recommended bolt's grade for a similar case?
Old 06-13-2009, 02:13 AM
There are several options. You can get zinc plated alloy steel allen bolts in grade 12.9, part number 95263A388, box of 25 for $5.88 The stainless bolts in metric seem to have higher tensile strength, minimum 101,000 psi, so that is an improvement. If going with stainless, you might as well go with 316, which has 2% molybdenum and can resist salt water and other contaminants that 18-8 can't handle. That would be part # 92290A242, box of 25 is $9.17 I'm just guessing a 20mm thread length. Another possibility if you have total design control and can spec the threads being tapped in the base is to go with #10-24 or #10-32 American threads, which are .187", only .008" smaller than 5mm. That gives you many more choices for the surface finish. There is an Ultra corrosion resistant bolt that is full 180,000 psi Grade 8 strength. That part number is 91274A112, box of 50 for $8.08, #10-24 x 3/4 thread length, page 3075. This is all in the McMaster Carr catalog online. www.mcmaster.com
Dave
Old 06-13-2009, 02:42 AM
these are a lot of options Dave, thanks for the fast reply
I'll take a look on the bolts you mentioned and see what fits
Just IN- PBC Linear Offers New Profile Rail Linear Guides Pacific Bearing Product Announcements & Manufacturer News 0 04-30-2009 03:53 PM
Self leveling Epoxy for making linear rail mounting surfaces mackeym Linear and Rotary Motion 37 11-10-2008 04:31 PM
What is the grade of linear bearing shaft garagefela Linear and Rotary Motion 2 08-02-2006 08:53 AM
question about thk rail mounting mwp DIY-CNC Router Table Machines 11 03-10-2005 12:10 AM
