Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 06-11-2009, 08:28 PM
JimmyL is on a distinguished road
Linear Pillow Block Slide Bearing Specs. How accurate will my cuts be?
Hi Everyone,
I'm currently building a diy CNC router and am having trouble figuring out what kind of linear Pillow Block Slide brand to get. In a set that im currently looking at there are these figures for the tolerances for x y and z movement:
Mx17.5 My6.9 Mz6.9 with rails at 48'' (4ft)
Im currently interested in cutting wood and hard woods with my router but want to move on to aluminum in the future. im ok with tolerances under 0.002" but anything above im not so sure. My 4'x4' frame is made up of 80/20 extruded beams. Are these tolerances ok for the producing accurate cuts without any 'jiggle' in the linear slide system?
Ive noticed other linear systems that have something along the lines of
Mx 4.x My 2.x Mz 2.x
Is there a noticable difference between these figures than the figures above them?
Old 06-11-2009, 08:51 PM
ger21's Avatar
Not sure, but the tolerances on the 8020 aren't that good. Straightness of 8020 is .0125/ft.
orientation of bearing block - vxb linear rail multiplex Linear and Rotary Motion 2 04-28-2009 01:20 PM
Need Help!- best or low cost soucre for buying linear bearing pillow blocks n shaft support ? sahilkit Want To Buy...Need help! 0 01-02-2009 06:39 AM
newbie Quest. Basic Static Load on Linear Bearing Block kNewton ? Calico Linear and Rotary Motion 4 06-27-2007 06:10 PM
small bore ball bearings w/ pillow block or flaged Blaise DIY-CNC Router Table Machines 0 05-22-2007 05:48 PM
Twin Pillow Block -- Cut in a Half OK? energyforce Linear and Rotary Motion 4 11-04-2005 06:29 PM
