Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-25-2009, 03:13 PM
mpictor is on a distinguished road
Ball screw sizing and machining
I have a geared head, round column mill/drill and a 10" Logan lathe (model 200?) that I want to convert to cnc.
I intend to use rolled ballscrews. What size do you recommend? I'd like to use the same size for everything, but I'll probably have to use something smaller for the lathe's X axis due to clearance.
I'll machine the ends myself if it's not too difficult. I remember seeing a site explain how to chuck the screw using BB's and a piece of tubing, but I can't find it. Can someone point me to a good description of the process?
Everyone talks about angular contact ball bearings. What about tapered roller bearings?
If anyone has converted one of these machines before, advice/drawings/pics/etc would be appreciated.
Mark
Old 05-25-2009, 03:43 PM
Bubba's Avatar
Bubba is on a distinguished road
I would use the "5/8" inch ball screw as they are the lest expensive and are adequate in size for most of our applications. I used them on my round column RF31 several years ago and am planning on using the same size on my 12X36 lathe.
Art
Old 05-25-2009, 03:51 PM
Yeah, I saw the 5/8" ones were significantly cheaper in McMaster, so I was leaning that way.
I forgot to ask: what brand(s) would you guys recommend?
Old 05-25-2009, 04:03 PM
Bubba's Avatar
On my mill/drill, I use Roton and on my lathe, I got a stick of Thompson to use.
I think this boils down to a Ford/Chevy debate on which one is better. What matters more is what precision you want (remember, better precision is spelled $$$$$$$)
Art
Need Help!- Trouble Machining Ball-screw End Adamj12b General Metalwork Discussion 4 11-27-2008 04:50 PM
ball screw machining tooManyHobbies Benchtop Machines 6 10-18-2008 03:32 AM
Need Help!- Trouble Machining Ball-screw Adamj12b General Metal Working Machines 6 07-23-2008 03:12 PM
Machining Ball screw ends Ferrari2007 DIY-CNC Router Table Machines 4 05-06-2008 07:30 AM
machining ball screw KEYTEEM Linear and Rotary Motion 25 08-29-2006 06:27 PM
