Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-21-2009, 11:34 AM
Robotics Guy is on a distinguished road
What kind of screws should I get?
I'm a student in high school just starting to make my own PCBs. When I make a PCB I have to drill over a hundred holes with a dremel, and these holes are really small making the dremel bits very easy to break. To solve this problem (and to have another fun project!) I'd like to build a very little, very cheap, CNC machine.
The boards that will be drilled with my dremel are only about 3"x4". What exactly do I need to buy to make the board move back and forth so I can plunge the dremel down and drill the hole?
I'm looking at some 12" screws on e-bay right now (I'm assuming a 12" screw would be long enough, since my board is only ~4" long?): http://cgi.ebay.com/eBayISAPI.dll?Vi...m=330332172328
Thanks for the advice!
Old 05-26-2009, 05:29 PM
veteq is on a distinguished road
Hee there,
Better to buy some second hand ballscrew on ebay, cheaper.
most include bearingblocks.
they where new very precise and more still far more precise than the leadscrews you linked to.
expect to pay at least 1000 dollar for a working machine.
you need
mach3 160 dollar
stepper drives+stepper 200
ballscrews ebay 200 can cut them to the lenght needed.
linear guides 200
a bit alu and milling 200
if you would like i can make you a nice concept design tommorow??
regards,
Roy B.
http://search.ebay.com/_W0QQsassZyishi_xingtaiQQhtZ-1
http://search.ebay.com/_W0QQsassZjak8858QQhtZ-1
http://stores.shop.ebay.com/d-kwa252...34Q2ec0Q2em322
Old 05-27-2009, 01:13 PM
Roy, thanks so much for helping!
I was hoping to build this for around $300.
This is a hobby project, for learning and having fun, so I'm planning on writing the software myself. Meaning that I won't need the Mach3 control software.
I got some stepper motor drivers free as samples, which I think will work with these cheap stepper motors: http://www.alltronics.com/cgi-bin/ca...brand&start=30
The ballscrews you linked to on ebay are only about $30 dollars each, with $20 dollar shipping. Do I need more then two screws? If not, it looks like the screws will cost about $100 total.
Would it be possible to make the linear guides myself, from cheap metal tubing or something? The boards I'm going to be drilling weight almost nothing, so the guides do not need to be very sturdy.
I have a dremel that should work very well for drilling PCBs, does that eliminate the "milling" cost above?
That would be great!
Again, thanks so much for your help!!
Old 05-27-2009, 01:47 PM
if its low budget you can make it youre own,
just read a lot on the forum.
thinks you will nead 3 screws.
regards
Old 06-03-2009, 09:48 AM
venomx999's Avatar
venomx999 is on a distinguished road
If its just tracing and drilling boards. You oughtta check out www.instructables.com They got a small cnc made from pipe metals. It would be the least amount of $ spent on the project.
Live life like you never see another day
Old 06-03-2009, 12:33 PM
pminmo's Avatar
pminmo is on a distinguished road
Actually for a small pcb machine, plain old all thread 1/4-20 is fine.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
What kind of cmm would you buy? joecnc1234 Polls 3 04-07-2007 02:38 PM
Ball screws, Acme screws, threaded rod DJ Morrow DIY-CNC Router Table Machines 11 03-22-2007 12:39 PM
What Kind Of CMM? ajl6549 Calibration & Measurement 0 03-01-2007 11:57 AM
What kind of screw is this? tanky321 Linear and Rotary Motion 4 01-18-2007 02:53 PM
What kind of computer do you use for your CNC? ipodman1991 DIY-CNC Router Table Machines 0 01-08-2007 08:18 PM
