Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-17-2009, 10:02 AM
vger's Avatar
vger is on a distinguished road
Accurate rotary to linear translation
I recall the early 5 1/4" floppy drives used stepper motors for head positioning with a metal ribbon assembly. They had an aluminum drum attached to the stepper with a split metal ribbon wrapped around it whose ends were attached to the head assembly. It seems to me that a slightly upscaled system using larger metal strap and a larger drum (perhaps banding material) might be workable. One might even be able to incroperate the drive motor into the drum in some manner.
Steve
Old 05-17-2009, 10:28 AM
Al_The_Man's Avatar
There are some sytems like this out there, this is one
http://www.stegmann.com/product/linear/index.html
If that is what you had in mind.
I used some on a hydraulic cylinder positioning application that worked out well.
Old 05-17-2009, 10:29 AM
Steve, you might try www.belttechnologies.com indexing belts.
Dick Z
DZASTR
Interesting rotary to linear action BillTodd Linear and Rotary Motion 0 01-19-2009 11:54 AM
Which linear bearings most accurate? acpkenny DIY-CNC Router Table Machines 0 12-02-2008 06:58 PM
idea for cheap but very accurate linear scale henry_phd CNCzone Club House 1 10-17-2008 11:04 AM
Rotary to linear torque converter. flakker Mechanical Calculations/Engineering Design 0 03-21-2007 07:55 AM
