Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 05-16-2009, 03:11 AM
p_rabid is on a distinguished road
help for mount bearing ballscrew
sorry for that question kind of idiot question
i have ball screw 16mm i want to make the end support bearing something like that how can i do that
i got bearing 16mm and machined the ball screw about the 15.95mm and make aluminum block and machined to fit the bearing on it ????
i make this on both side of the ball screw or what ????
and other question about the pinion and coupling
what is the best to use pinion or coupling to the shaft of the motor i got about 9 KG/CM holding torque bipolar stepper motor
my machine about 70 CM* 50 CM *15 CM it small for pcb milling and drilling
thanx in advanc
How to mount lead screw inside a bearing? CuttersCov DIY-CNC Router Table Machines 24 08-13-2011 07:25 AM
Bearing mount vger Mechanical Calculations/Engineering Design 2 02-08-2008 01:56 AM
Ballscrew Flange and Linear Rod Mount? barkster Linear and Rotary Motion 0 05-03-2007 02:32 PM
Need a source for this bearing mount/assembly SteveL Linear and Rotary Motion 2 09-17-2006 07:43 PM
Cheap DIY bearing mount countmacula Open Source CNC Machine Designs 3 05-11-2006 05:33 PM
