Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-29-2009, 04:43 PM
escott76 is on a distinguished road
Grease fittings for Hiwin 20mm blocks
Having a hell of a time finding compatible fittings for the Hiwin 20mm series of guides and rails. According to the spec sheet, and confirmed by measurements, the thread seems to be a metric 6mm X .75mm. What is available is a 6mm X 1mm fitting, at least as far as I've found. Either one of the blocks I ordered was missing a fitting, or I misplaced it, but either way I need to pick up some new ones, and straight ones at that instead of the 45 degree ones that were supplied. Anyone have any advice where to find these things?
Old 04-29-2009, 09:40 PM
Jason3's Avatar
Jason3 is on a distinguished road
Eric ('Widgitmaster' Eric... ) was looking for the same size IIRC, he was able to get them somewhere near him. You might have a search and see if he mentions where he got them. If you get real stuck, I have some - let me know & I can send 'em over.
Best regards,
Jason
Edit - Widgitmaster found them at an auto parts store...
http://www.cnczone.com/forums/showpo...&postcount=424
Lube fittings dblais Mazak, Mitsubishi, Mazatrol 4 05-01-2008 01:04 AM
need hiwin cad files for old ag series rail and blocks eloid DIY-CNC Router Table Machines 0 03-10-2008 08:36 PM
hiwin guide blocks and rails eloid Linear and Rotary Motion 5 12-10-2007 05:46 AM
What size THK/Hiwin rails and blocks? Zumba Linear and Rotary Motion 8 08-24-2006 11:10 PM
Bijur Fittings arsenix Bridgeport and Hardinge Mills 12 10-12-2005 07:36 PM
