| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| Which Ball Screws to use? Hi Guys I need some help Guys? I am trying to decide which size of Ball Screw I should be installing in the Mill that I am converting to CNC? You can see a picture of the Mill below. The Mill will be used mainly to machine Aluminum with a little Steel. I do plan to use the Mill allot. So it’s either 5/8” or 3/4” Screws? I was originally planning to use 5/8” Screws but have been told by more than one person that I should be installing the 3/4” ones. What do you think about this? Here is a list of the other components I will be using: (Servo Motors) C23-L55 Poly-Scientific. Peak Torque = 430 oz.in. Continuous Stall Torque = 50 oz.in. Rated Torque = 40.5 os.in. Rated Speed = 1700 rpms. (Ball Screw Nuts) Pre-loaded Ball Nuts with Wipers. (Uses two single circuit nuts per screw) (Ball Screws) Linear Error per foot = 0.001 to 0.003 Screw mounted on double Angular Contact Bearings (Drives) Belt drive with a 2:1 ratio between Servo Motor and Ball Screw. (Mill Sliding Surfaces) Original Cast Iron Ways. Thanks for the help. Willy |
| I am using 5/8", as have many others. 3/4" would of course be better but more money. Eric
__________________ I wish it wouldn't crash. |
| Hi Balsaman Approximately how many hours do you think you would have on your 5/8" Ball Screws? Have you noticed any wear (increased backlash) on the Screws since they were installed? Approximately how often do you lubricate your Screws? I guess what I am trying to figure out here, is the benefits for going with a 3/4" Screw instead of using the 5/8” ones? As far as the maximum load difference between these two Screws, it’s only 125 lbs. 5/8” Screws are rated at 825 lbs. and the 3/4” ones are 950 lbs. I guess for the same applied load, the 3/4” Screw will more than likely last longer because it has more area to carry the load. I can’t see machining pressure being anywhere close to the 825 lbs. rating of a 5/8” Screw, especially when working with Aluminum. Maybe I am missing something here, but I just can’t see that much of a benefit by going with the larger Screws? Price difference between the two is approximately $250.00 which is a little more than half the cost of the 5/8” Screws. Anyway’s, I need to make up my mined soon and would be interested in hearing any and all comments with either setup. Thanks for all your help. Willy |
| Revolutionary Linear Drive System | allanconway2 | Polls | 21 | 05-03-2009 09:27 PM |
| Ball Screws & Nut Advice | coolman | General Metal Working Machines | 1 | 12-24-2004 09:29 AM |
| Correct Pre-loaded on Ball Screws? | Willyb | General Metal Working Machines | 3 | 12-09-2004 10:09 AM |
| Ball screws singles/doubles/preloaded??? | replicapro | General Metal Working Machines | 18 | 06-18-2004 12:48 AM |
| Z-Axis and Ball Screws | samualt | DIY-CNC Router Table Machines | 15 | 01-10-2004 03:10 PM |
