| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| Hi, Go here http://www.nookindustries.com/acme/AcmeCalculators.cfm and look for the “critical speed” section. Click on the link to a calculator and punch in your numbers. John |
That is one heck of a helix angle, something like 35 degrees I think. Have you found a source? I would expect cutting a thread like this would be a challenge and its driving efficnecy would be very low.
| Actually, the efficiency is much higher, probably near 80%
| McMaster Carr sells the 8 start and Joe of Joe's CNC has them installed on his 4'x4' hybrid. They seem to work quite well and he's exceeding 300IPM on it. Of course with that 1 inch per rev the torque is lower and step size is up to .0005 but just what wood really needs .0005 precision? As long as no steps are lost the results should be indistinguishable from 1/2-10 single start. |
1/2 inch acme with double bearings on each end can do 311 RPM max (106" between bearings to allow for a 10" traveller) which probably means the DIY guy should look at the dual single bearing speed of 212 RPM when using double bearings. So I should probably be looking at a 3/4" leadscrew if I want a reliable 300 RPM. |
| acme 2 start rod vrs. gear up box on z axis | drummer 1 | Linear and Rotary Motion | 2 | 02-07-2009 06:38 PM |
| 1/2-8 2 start acme tap? Anybody know where to get one? | mxpro32 | General Metalwork Discussion | 8 | 09-27-2007 08:34 PM |
| 2-Start 1/2" 10 (5 TPI) acme tap?!??! | ewest | Linear and Rotary Motion | 4 | 03-21-2007 07:40 AM |
| Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help | pandiyan.innova | CNCzone Club House | 7 | 11-16-2006 05:47 AM |
| Multi Start acme Rod? | boxwood | Linear and Rotary Motion | 2 | 06-30-2005 06:27 AM |
