Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-17-2009, 12:06 AM
cyclestart is on a distinguished road
preload by selective ball
Replacement balls are available in .0001" increments. How do you decide what size to order ? At ~$12 plus shipping per set, to much guessing could get expensive
Current backlash is .008"
Why does a screw that appears to be 4 tpi move half an inch/rev ? The ballscrew has a red label marked "Warner Electric" and has 2 ball return guides, one on each side of the screw.
Anyone who says "It only goes together one way" has no imagination.
Old 04-17-2009, 12:20 AM
Originally Posted by cyclestart View Post
.....Why does a screw that appears to be 4 tpi move half an inch/rev ? The ballscrew has a red label marked "Warner Electric" and has 2 ball return guides, one on each side of the screw.
Double start thread.
The pitch is .25 but the lead is .5
Pitch is distance between adjacent threads, lead is distance travelled in one revolution; it is actually a 2tpi (turns per inch) screw.
Old 04-17-2009, 12:29 AM
DOH, caught me before I could cover my tracks
Figured it out with a felt marker (but not fast enough ),
Old 04-21-2009, 08:24 AM
Taking a closer look at things the backlash varies between .008" and nearly 0 depending on where it's measured. This screw is for the garbage.
Still curious if there's a rule of thumb when buying oversize balls .
No bad jokes or puns please
Dont know which size ball to use to preload ballnut maxboostbusa Linear and Rotary Motion 6 01-09-2008 11:51 AM
Pneumatic Preload Ball Nuts coop2005 Linear and Rotary Motion 2 11-28-2007 08:01 AM
preload ? andy55 Linear and Rotary Motion 5 01-04-2006 06:28 PM
Preload Thomson Ball Nuts powerfade DIY-CNC Router Table Machines 2 11-08-2005 10:42 PM
strange bearing preload threads on ball screw mxpro32 Mechanical Calculations/Engineering Design 1 03-10-2005 08:07 PM
