Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-14-2009, 02:47 PM
exit104's Avatar
exit104 is on a distinguished road
Thumbs down Mounting open slide bushings.
I am building a mod on the Solsylva 24x24 machine. As I am a bit of a mechanical yutz, I am going to use commercial (used) slide bearings instead of skate bearings and black pipe.
I just bought a set of 2 Nippon Bearing linear slides with SW12G open slide bushings and a WA 12, fully supported base.
I expected to be able to get a housing for the bearings that would allow me to connect them to the gantry. Alas, I cannot find housings without bearings already in them.
So, what is the proper way to connect these bearings to a gantry? Do I need to create a custom fixture or am not looking in the right places for the housing?
Thanks!
Andy Otto
-*Andy*-
Tags
linear, open, router, solsylva
where to buy linear bushings? slat26 Linear and Rotary Motion 3 03-04-2008 12:34 PM
RFQ 4 turned bushings SPEEDRE Employment Opportunity 4 01-16-2008 03:53 PM
Mounting dro scales to the cross slide wrenchcruncher General Metalwork Discussion 4 01-07-2008 06:27 PM
Nylon Bushings John3 General Metalwork Discussion 4 08-08-2007 10:57 AM
RFQ: Aluminium Bushings levelzero Employment Opportunity 3 03-01-2007 01:04 PM
