Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-26-2009, 05:36 AM
semo is on a distinguished road
Question Pre-Loading force
I am building a W-EDM and I will make an AB nut for it.
just like this one
I was wondering, how could I calculate the preloading force of the spring. I know it must exceed the load of the carriage but how can I calculate it in terms of spring parameters?
Will be waiting for reply,
Old 03-27-2009, 09:39 PM
Oldmanandhistoy is on a distinguished road
I can't really help but here's a link that might point you in the right direction for "spring parameters".
http://www.engineersedge.com/spring_menu.shtml
John
Tags
pre-laoad
pressure vs force pit202 Haas Lathes 0 10-10-2008 02:30 PM
how to figure force? jessslp05 Linear and Rotary Motion 2 05-05-2008 08:43 PM
Need to know how much force in psi RedDog22 Mechanical Calculations/Engineering Design 17 01-05-2008 04:32 PM
How much force on a cutter ? vroemm Mechanical Calculations/Engineering Design 4 06-14-2006 02:04 PM
Air cylinders, PSI & Force they have ??? Chris D Mechanical Calculations/Engineering Design 27 04-30-2006 11:23 PM
