Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 03-01-2009, 10:52 PM
kevintshaver is on a distinguished road
mounting location for rails
Hi.
I want to make a fully supported base. I want to use the supported round 20mm rails with the partially open bearings for the x-axis slides. The base will be 1530 80/20 Al extrusion.
The main question is what is the best orientation for mounting the rail base?
1) on top of the frame so the round rail is directly above the frame or
2) mounted on the side of the frame
A secondary question is if anyone has any tips or tricks for mounting the rail base to the extrusion. Just drill and tap holes in the extrusion to match with the rail base holes or are there any 80/20 mounting plate adapters out there?
Thanks!
Mounting rails on glass - how flat is glass? Swiss Linear and Rotary Motion 50 07-25-2008 02:10 AM
Z-axis - mounting rails on spindle side, rather than tower side guru_florida Linear and Rotary Motion 7 01-31-2008 06:54 PM
Gantry X-axis mounting location aaron800 Linear and Rotary Motion 3 02-27-2007 12:29 PM
Design of plasma table, high rails or low rails? Apples CNC Plasma and Waterjet Machines 3 12-18-2006 02:21 PM
mounting linear rails side by side 50062040 Linear and Rotary Motion 1 10-24-2005 07:49 AM
