Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-27-2009, 05:17 PM
slinger1010 is on a distinguished road
Sleeve Bearing question
I was planning on using a sleeve bearing on my CNC mill but then I had a thought... How to you stop them from moving.
The ones I'mm looking at are from McMaster Carr 6338K423.
Do you press these in? I would think that would distort them as would a set screw. So how do you normally set these in place?
Ron
Old 02-27-2009, 06:39 PM
Bada Bing is on a distinguished road
That would be a press fit with a bore or ream to size post press.
H
Need Help!- How to do a Hex Sleeve on Long Shaft? melt_fire General Metalwork Discussion 13 01-04-2011 11:37 AM
Sleeve Valve engine nlancaster I.C. Engines 3 06-03-2009 02:05 AM
MT5 shank to R8 socket sleeve veggiedog General Metalwork Discussion 3 02-04-2009 03:55 PM
where to get bronze sleeve bearings in the uk ? fenton Linear and Rotary Motion 10 03-06-2007 11:15 AM
How do I machine this: Bearing Sleeve CuttersCov General Metalwork Discussion 6 03-05-2006 02:44 PM
