Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-26-2009, 06:13 PM
nobikes's Avatar
nobikes is on a distinguished road
Home made linear bearings,
i am thinking of making my own linear bearings for a CNC router i am making with my students. Would it work if i used a accurate 1" reamer and reamed out a piece of brass to run on a 1" piece of CR steel?
thank you
Old 03-07-2009, 09:19 AM
vger's Avatar
vger is on a distinguished road
Try bronze bushings (some available at home depot even) polished CR.
Old 03-07-2009, 09:29 AM
beege's Avatar
beege is on a distinguished road
Reaming is iffy, depending on your setup. I'd rather bore to just under, then hone to fit (shaft may measure 1", but may be out of round.
Home made ATC pstockley General Metal Working Machines 21 11-09-2009 04:12 PM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 10:06 AM
Linear Motors for a home made machine? NEATman Linear and Rotary Motion 8 05-12-2006 08:30 AM
Bearings for home made linear Alaskan DIY-CNC Router Table Machines 12 08-14-2005 01:09 PM
Home made CNC mill (and some products made by it) gcamlibel DIY-CNC Router Table Machines 23 04-05-2004 05:54 PM
