| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| rack and pinion hello all. Does anybody know where You can order precision rack and pinion on- line? I'm not looking for super precision, something around .oo4 would be fine. I found some in the msc big book but I dont think it is precision stuff. It doesnt even say how accurate it is. Help would be appreciated. PS what can one expect to pay for precision rack and pinion for about a 4 foot length? |
| See this forum post, Boston gear is good, if you want higher precision you can order online from QTC Sterling products, they make a good precision rack with matched machined ends. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| have you ever used the boston gear rack? how precise is it? Im using it for wood working ( routing ) not machining but would still like around .004 acurracy |
| I wouldn't worry too much about the accuracy of the commercial rack, its likely quite uniform. Its more a matter of "how accurately can you mount it, and how good of a fit will you make with the pinion?" The control of backlash through all the driving components is where the problems will arise.
| can you still run a rack system on a 5ft table or is this not recommeded |
| There are alot of commercial tables that run over 20 ft with rack, I have retrofitted a 100ft gas/plasma table with a 12 pitch rack ( see some earlier links for photos). Al.
| thanks AL |
| Linear Motion FAQ | Cutters Cove | DIY-CNC Router Table Machines | 6 | 09-30-2009 02:36 AM |
| Rack & pinion | coolman | DIY-CNC Router Table Machines | 6 | 05-07-2006 05:14 PM |
| Spring Loaded Rack and Pinion request | ty1295 | CNC Plasma and Waterjet Machines | 1 | 02-08-2005 12:15 AM |
| Rack & pinion | coolman | DIY-CNC Router Table Machines | 3 | 11-30-2004 11:57 AM |
| calculatiing pinion size for rack and pinion setup | Apples | DIY-CNC Router Table Machines | 3 | 05-18-2004 10:36 PM |
