| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| I have seen some nice tiny ones on Ebay at times. I bought some precision acme screws with antibacklash nuts that seem pretty nice. They are 3/8" diameter. I haven't actually used them yet, but may on a small build eventually.
__________________ Lee |
| Hi Vince, Sounds like a great project! Will there be a build thread? ![]() What size ball screw would fit? I know Steinmeyer were offering 3 mm dia. ballscrews a few years back. From what I've seen, 10 mm is the small end of commonly available screws, but 6 and 8 mm can be found too. I had a couple of 8 mm ones, they were certainly nice and compact, and didn't feel too fragile... I threw them in with a lot of surplus used ballscrews I sold, otherwise I'd have given them to you Best regards, Jason |
Vince |
| Vince, I hear you on the accuracy requirement. If you can find proper ballscrews, more power to you. Don't have anything to add there. But, if you can't, consider an alternative. The forces involved on a tiny lathe are pretty small. Delrin nuts on an ACME screw such as what Widgitmaster uses on his router might actually work pretty well for you. The Delrin springs back after the cut, which pretty well takes out the backlash. The material has a built in lubricant (Teflon), so friction is low. The disadvantage is that enough force will either deform it, or wear it out really fast, but you don't have that problem. You might take a gander at how Widgit approaches making them, or even get in touch with him about the backlash. He could certainly measure what he gets from one. You could make a neat little screw and nut combo up really quickly to try it too. You could also make a preloaded double nut system out of Delrin on Acme pretty easily that would further remove any residual backlash. Cheers, BW |
| I am using a Delrin nut on my Taig lathe CNC conversion. I was hoping for ball screws because of the forces involved. The steppers for this project will have to be pretty small. There is quite a bit of friction in a Delrin nut if you have it tight enough to prevent backlash and at those forces, I would have to build it much heavier than I would like to prevent an twisting. Vince |
| Bob, after your suggestion I looked into acme screws a little more and found that Nook has one that will work for me. It is 1/4-20 thread with plastic nuts. With my 200 steps per inch steppers, even without microstepping I will have an accuracy of .00025". The screws has an accuracy of .0003" which is better than rolled ball screws. The plastic nuts have a backlash of .006" so I am going to cut them in half and put a spring in between the two halve which will give me zero backlash with the light loads I will be seeing. I bought some very low profile linear rails from eBay that will work for the carriage and cross slide. It will be an interesting project, I just hope I can work on it along with all the other projects I am playing with. Vince |
| If you are going the ACME route, have you checked out http://www.dumpstercnc.com/ for anti-backlash nuts? He doesn't have 1/4-20 but he does have 1/4-16. That would still give you great resolution. |
Vince |
#11
| Vince |
#12
| Levin, that's a fine lathe. 8mm? How low of profile are your rails/carriages? Randy |
| Ball screws | htto | Benchtop Machines | 4 | 07-21-2007 07:30 AM |
| ball screws | morbius | Bridgeport and Hardinge Mills | 2 | 06-05-2007 03:37 PM |
| Ball screws, Acme screws, threaded rod | DJ Morrow | DIY-CNC Router Table Machines | 11 | 03-22-2007 12:39 PM |
| Which Ball Screws to use? | Willyb | Linear and Rotary Motion | 4 | 01-19-2005 08:49 PM |
| Ball screws | BluesMagoos | General Metal Working Machines | 1 | 01-08-2005 12:09 PM |
