| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
I have a HSR35 slide it looks new, slides smoothly, but requires a lot of force. I assume it is preloaded. I have been unable to decipher the options form the THK site. Rail is marked - UGIE5 . Block is marked Y0112. Is it preloaded and can the preload be adjusted or removed? Thanks, Mike Last edited by mfisch2001; 02-08-2009 at 07:21 AM. Reason: Correction |
| I do not know whether the preload can be changed but I suspect that if you can, it would just be a matter of using different sized balls to achieve higher or lower preload. One thing to try first is press down on the bearing block while sliding it. These rails, especially large ones like yours seem to need some load on them to get them to slide smoothly. Also make sure that the "rubber" seals on the blocks have some lube on them to as sometimes they can stick a bit. What are you planning to build with those massive rails? |
I have a big one by Hiwin, it move and slide easily and smoothly, like no restriction. It is new one. I do not think if it needs preload, it looks like rigid, no side movement while sliding. Block is about 15 cm by 15 cm. Rail is about 8 cm by 8 cm. Thanks. Asuratman. |
Mike |
| preload on spindle bearing | adryan | General Metal Working Machines | 7 | 06-21-2010 05:59 PM |
| locknut for bearing preload | lagfish | Benchtop Machines | 14 | 01-11-2008 03:57 PM |
| Bearing Preload w/Lovejoy Connector | rcazwillis | Linear and Rotary Motion | 21 | 07-23-2006 05:43 AM |
| strange bearing preload thread on ballscrew | mxpro32 | Benchtop Machines | 14 | 03-22-2005 01:23 PM |
| strange bearing preload threads on ball screw | mxpro32 | Mechanical Calculations/Engineering Design | 1 | 03-10-2005 08:07 PM |
