Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-30-2009, 06:10 PM
cxixer is on a distinguished road
Rack & Pinion Design ?
Here is a design I am thinking of using for my rack and pinion drive. My original router design used R&P, didn't work because there was no spring putting tension on the rack. It would work itself loose and screw up my pieces that I was cutting. I am going to basically build an arm and use a spring to press it up against the rack, similar to other designs I've seen around here. This arm will be made of MDF, using bearings around the pivot screw and the motor shaft. In the future I will replace this with aluminum, and may gear it down, but I was happy with the resolution and torque before, so I'm sure it will be fine.
Why do this? To fix the rack setup in the first place I replaced it with 1/2-10 acme screws. Well, now it's slow. Accurate, but very slow - 30ipm max. I'm sure most of this is adjustment, but even if that is perfect, I will not get even 80ipm. Multiple start screws are expensive. I already have this rack setup, and even gearing if I want to gear it down. Live and learn.
Specs: I will be using 1.5" MDF plus another 3/4" to mount the motor so there is clearance for the setscrew so it does not interfere with the bearings. The bottom of the rack is about 5.25" below the bottom of the side of the gantry. The arm will be about 11" long. I am using a 5/16" bolt and the same size skate bearings for the pivot arm (that's what I have laying around). I will be using a 1/2" shaft to connect the motor to the pinion, and the same size bearings to support the shaft. The arm will essentially be pulling up on these bearings.
Please excuse the drawing, I can CAD only enough to sell my products.
My questions -
Is there a more efficient lever design than this? Without actually building/testing, it seems like it will take a significantly strong spring to apply enough pressure.
Will the bearings I plan to use be sufficient?
Any other suggestions? Anything I havn't thought of?
http://www.homebrewedtechjunkie.com - My techie projects, including a cnc build.
Old 01-30-2009, 06:20 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
Check out mechmate http//www.mechmate.com on there they say that the arm should be parallel (or very close to parallel)with the rack to help eliminate the gear from wanting to climb out of the rack.
Old 01-30-2009, 06:58 PM
LeeWay's Avatar
LeeWay is on a distinguished road
I'm not sure that MDF will even hold up to the torque for very long. If you can cut MDF, you can cut plastics and even aluminum. Steel would be ideal I think. You could even use off the shelf steel parts and design the rest to fit the bar. Steel bar is available in many hardware stores or any welding shop.
This will be a high stress point. The rest of the machine can remain as is I guess, but this is one area (drive point) that you really shouldn't skimp on.
I was building a large 5 by 10 plasma cutter. My mill worked out so well that I no longer need it. I bought steel and racks for it. I plan on seeing how the rack will work on a small steel frame machine with the motors mounted fast and traversing the rack. I think I should be able to get decent speeds, with a little slower acceleration without the gear wanting to jump the rack. It has to be a rigid build though in order for this to work.
My other builds were for production in my one man shop, but this will be testing a design and be more of a little hobby machine. Likely stick it on Ebay when done. I am only in design so far.
Good luck with it.
I know a slow machine is aggravating, but speed and rigidity costs extra. The more you throw at a design, the better it should get.
Lee
Old 01-30-2009, 07:15 PM
In theory, the arm will be parralell with the rack...
Yeah, I can cut plastic, a bit of chatter, but do-able (hence the reason for the upgrade). I could make these out of Polycarbonate, I have that laying around as well. Would I be better off Using .5" or .75" polycarbonate for the arm? I have .25 and .375" polycarb and can laminate it together.
This is actually a very simple design and wouldn't even need to cut it on the router, I could do it by hand.
I do realize polycarb flexes in one direction very badly, but in the other direction, it is very sturdy.
I am re-doing the x axis with vbearings, the z with aluminum extrusion and NSK linear bearings... These rack drives would be the only MDF, and would be short-term... But if polycarb would work long term, I would do that right away.
What do you think?
Old 01-30-2009, 11:26 PM
Gerald_D is on a distinguished road
Have looked at your sketch, and if your proportions are right, that layout will give you some headaches. If the motor must push the car to the right, the pinion will climb out of the rack.
What you need to try and do is to lower the hinge point of the arm. The best place for the hinge point is at the same height as the rack, but it is not essential to go that low. You can screw a plate to the car with a hinge point lower down in that plate.
In effect this will make your arm nearer to the horizontal.
Gerald
www.mechmate.com
Old 01-31-2009, 12:27 PM
Gerald
www.mechmate.com
Is that what gary was talking about above? I misunderstood. But I get it. Attached is another drawing. I don't have a measurement for the plate ... or a great way to cut the plate... but this should make the arm that holds the pinion about 7-8" as opposed to 11", which will make it sturdier as well. The only other thing I could do to this plate is lower it further on the hinge side to make it under the rack, it couldn't be perfectly in line with it because I have maybe 1/4" clearance and that's not enough for a bolt to stick through to secure the arm onto it. I may have to do this anyway, as the lowest that pivot point could be is about 2.5" higher than the rack because of this clearance. Would I be better off staying as is, or lowering the arm past the rack?
I was thinking I must have overlooked something, and not only will this help the pinion stay on track, but I think it will be more efficient in terms of pulling into the rack itself. Not as much spring tension.
Gerald, do you think the 3/4" polycarbonate will work in this situation? So far (before I hit the machine shop) I've kept my upgrades to about $250, I'd like to not go too much higher, all I still need are two .5" aluminum plates for the z axis, and my ballscrew machined.... I think. If I get these arms milled from aluminum I just threw the cost savings out the window.
Old 01-31-2009, 12:38 PM
If I brought the pivot point lower than the rack...
Old 01-31-2009, 01:29 PM
Our MechMates all have 45 degree arms - they work fine.
You do not need bearings at the hinge point since the theoretic rotation is nil. We use bolt & nylock nut with some plastic washers for friction.
See: http://www.mechmate.com/forums/showthread.php?t=1055
Gerald
Old 01-31-2009, 02:47 PM
Al_The_Man's Avatar
I used these items on a large gantry for the pivot point tensioner http://www.rostainc.com/pdfs/rostainfo9.pdf very simple.
Here is the example in post#12 & #13, the first was a spring tension method the others were the Rosta method.
http://cnczone.com/forums/showthread...ighlight=rosta
Old 03-02-2009, 06:51 PM
OK, I've made my upgrades.. for the most part. But there's a problem. Attached are some pictures of the new router (note it has a brand new MDF table with t-nuts for hold downs not shown). The problem is I'm losing steps somewhere. I went out and tried to cut some rings (gcode attached) and what is supposed to be 13"x13" square comes out to about 12 15/16" x 12 1/2". Now explain that. The circles were also completely screwed up. I cut it twice, once as is, and then I noticed my set screws were not tight on the x axis pinion (shown attached to the router plate), so I tightened them and used loc-tite ... again. The second time the circles got just as screwed up, but the squares are pretty much perfectly the same. So the repeatability is great...yay...
Now everything looks very tight, I do not have a dial to measure backlash, but again, looks tight.
How tight do these springs need to be pulling the pinion towards the rack? Could that be my problem? I can push them down off the rack with finger pressure, but it takes quite a bit of force pushing on an axis to get them to jump off the rack. I don't know their force or anything, I just chose springs that were pretty tight from ace hardware...
ID:	76700   Click image for larger version
ID:	76701   Click image for larger version
ID:	76702   Click image for larger version
  #11   Ban this user!
Old 03-03-2009, 12:08 PM
harryn is on a distinguished road
Hi, I have been reading about racks, but have not built mine yet - so take this "advice" for what that is worth.
I think I read (somewhere - maybe mechmate) that you need about 80 lbs of holding force to work a cnc router - so I just keep using this number in my calculations.
Try taking the oz- inches of your stepper motor and the pinion pitch diameter and see how close you come to this.
Example 500 oz - in motor (max), 2 in dia pinion
500 oz - in / 1 in (radius) = 500 oz
500 / 16 oz = 31 lbs of holding force (maximum)
So, while it is a strong motor, it probably is not enough torque without gearing down or a smaller pinion.
The minimum pinion size for a given pitch is sort of limited by the point where the tooth interface is no longer the right path (see boston gear - very detailed explanation). In the end, for common tooth pitches, you sort of end up with 1 in min pitch dia. This means it almost takes 700 - 1000 oz in motor to make it work without gearing down. (assuming the 80 lb holding force number)
In theory, you can go to very fine pitch to get around this problem. There is metric pitch rack that is called out as I think M1 or M1.5 - something like this. When you run the tooth strength numbers, it is hard to achieve the 80 lbs numbers this way unless it is a high strength steel (expensive)
Another place to look is the stepper motor driver settings. The drivers tend to reduce the current when the motor motion is idle to prevent overheating, thus - reducing torque even more. I think you can adjust this setting, but I don't know how.
As far as the spring, I would have guessed that you need more like 30 - 50 lbs of force to keep it firmly in the rack, but that is a guess.
  #12   Ban this user!
Old 03-03-2009, 01:31 PM
So after reading this post a couple of times I'm still confused. I guess I havn't read that much about racks. Does the cutting force or speed come into these equations at all? It seems like the harder the force on the bit, the more spring force would be needed.
Again, I don't understand your numbers really, but I'm using 425oz-in motors, 16 pitch racks, 24 tooth pinions, direct drive. I do have some belts/gears to gear the setup down 3:1, but it would be a pain to make the parts. It would be more of a pain, though, to purchase absolutely anything else for this money pit, which makes new racks and pinions out of the question. I'd love to just get new springs, but I can make the gearboxes if I need to.
What are your thoughts?
Where do I get these different springs?
Need Help!- Concept Rack and pinion Design Mongkol Open Source CNC Machine Designs 7 11-12-2008 05:19 AM
rack and pinion design eloid DIY-CNC Router Table Machines 8 03-03-2008 07:29 PM
tuning servo motors for rack and pinion design eloid DIY-CNC Router Table Machines 1 11-10-2007 10:28 AM
rack&pinion new design bekx Linear and Rotary Motion 8 08-10-2007 04:12 PM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
