| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| View Poll Results: Will it work? | |||
| Yes, good idea..... | | 7 | 25.93% |
| No, no chance... | | 1 | 3.70% |
| Needs improvement.... | | 8 | 29.63% |
| Worth a try.... | | 11 | 40.74% |
| Voters: 27. You may not vote on this poll | |||
Hi everyone, I have attached some drawings of my idea of a simple skate bearing slide design. It consists of 2 5mm thick Aluminum plates that are machined from one side only. just some holes and 2 different depth channels. The Skate bearings are squeezed inbetween the plates the channels are slightly smaller than the diameter of the pin of the skate bearings and centers the pin when bolted together. The bolts on the upper side allow for pretensioning the upper bearing. Do you think that it will work? ![]() ![]() |
| Looks good, kind of looks like a simplified version or spin on the link below: http://www.buildyouridea.com/cnc/hbl...ototype_4.html |
| I actually was not intending to cut any threads. I think the aluminum plate and the sharp edges will serve as a bas for the bolts thread to bite itself in. So with cast aluminium I think it would be too brittle. Tha Idea was to being able to have it machined in a simple machine shop. |
| It looks good. Pretty easy mounts to make. The only issue I have with the design isn't in the design of this part at all, but in using unsupported rod. I would only consider that on a Z axis or a very small machine. These rods will have flex. Back and forth especially toward the center of the cutting area. Just not a rigid design from the getgo. Many guys do build this way though. I did a little testing before my first build and the amount of flex in a 4 foot rod was just unacceptable to me. I needed more precision than that. Once built, there is no fixing the flex unless you cam either live with it or redesign it. A much more rigid idea is flat bar or tube. Still not perfectly accurate. I did a combination of those and my rails are very stout. I get very nice accuracy now on my router. I used a very simple bearing design using 1/8" by 3/4" aluminum tube. I would say the cost was on par with your design with nice round rod.
__________________ Lee |
| Hi guys ! I've been inspired by the design shown by Jalessi a few posts before. I'm a beginner non machinist & don't know how to use Solidworks yet (i'm having trouble with my graphics). You can see my idea in the drawing below it's a very basic/crappy MS Paint drawing... i hope you'll understand ! I want to make the bearings of the right side adjustable by excentric for preload but will have to mod the design a bit...Any help ? I don't know the effect of hardned steel bearings rolling on an iron dovetail, i'm thinking to use grey iron machined from solid. What do you think ? How much will it cost in a basic machine shop ? (aprox price or expensive/lowcost or hours of work) I want to build a cnc knee mill the size of an X2/X3 and use this design for XYZ, the mill will be cast aluminium. What do you think ? The cool thing about this design is that you can lengthen/shorten it to suite your needs, IMHO. Any input is much apreciated. Thanks ! cnc2. |
#11
| This way I autumatically center and fix them... Last edited by bdahmet; 02-20-2009 at 08:24 AM. |
#12
| Try to design the whole router in solidworks, it will give you a better idea. Thanks ! cnc2. |
| Skate Bearing Blocks? | thebluedirt | Linear and Rotary Motion | 12 | 02-08-2009 07:59 AM |
| skate bearing supplier (sourced!) | tankie | Australia, New Zealand Club house | 4 | 10-04-2007 06:52 PM |
| Lifespan of a Skate Bearing. | Miata2k | DIY-CNC Router Table Machines | 9 | 09-22-2006 12:53 PM |
| skate bearing design | paul langwade | DIY-CNC Router Table Machines | 1 | 07-29-2006 07:56 PM |
| Skate Bearing Design | coolman | DIY-CNC Router Table Machines | 11 | 05-20-2005 01:25 PM |
