| Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here. |
| Please help, -- I'm reposting this here. I think I posted it to a dead thread earlier -- I need some guidance regarding realistic feed rates, accelerations, cutting forces etc. for stepper motor sizing calculations. I'm also hoping someone can give me a reality check on the results of my initial calculations. ** Seeking typical values for the following ** -What is a realistic rapid rate -Typical cutting rate for router in ¾ mdf -Typical cutting rates for 60watt & 100watt lasers cutting cotton fabric (bed sheet weight) -Typical cutting rate for plasma torch cutting 16 gage steel. -What are realistic accelerations for the weights indicated below? ** The machine ** The machine will be a multi-purpose XYZ table. Initially, it will direct the beam from a 60-100 watt CO2 laser for cutting cotton fabric. Down the road, it will also do plasma cutting and light router work. ** Controls being used ** Gecko G203V stepper drivers PDMX-122 breakout board Mach 3 software ** General parameters ** Gantry weight: 70 lbs Cross slide weight 30lbs Table size: 4’x 8’ Motor resolution 1.8 degrees per full step Motor resolution .18 degrees per microstep Desired linear resolution of .001” The X & & will be driven by belt. The Z will be ball screw. ** my attempt at the drive calculations ** Assuming 1.194 pitch diameter final linear drive pulleys for both axis, the necessary ratio between the motor and final drive shafts should be 1.875 to 1 to get the desired linear motion per micro step I calculate that, at this ratio, the driver will need to receive 16,666.7 pulses per second to run at the rapid rate of 1000ipm while the motor will be turning at 500rpm. Both the X and Y axis are linear belt driven with reduction between motor and final drive. I have not gotten to the z – axis calculations yet. The x axis which will move the gantry has the following specs: Mass to move: 70lbs Motor pulley: 1.194” Pitch Diameter Intermediate pulley: 2.387 Pitch Diameter Final linear drive pulley: 1.194” Pitch Diameter This axis needs 432 oz – in of torque to accelerate at 2 G’s The Y axis which will move the cross slide has the following specs: Mass to move: 30lbs Motor pulley: .637” Pitch Diameter Intermediate pulley: 1.273” Pitch Diameter Final linear drive pulley: 1.194” Pitch Diameter This axis needs 198 oz – in of torque to accelerate at 2 G’s How close am I? Thanks in advance! Roger |
| Good way to train employees ? | GITRDUN | Benchtop Machines | 16 | 08-17-2007 07:54 PM |
| Shoptask lath drive train replacement | kb7vms | Shopmaster/Shoptask | 2 | 05-08-2007 11:17 PM |
| Proper way to calculate steps/unit for belt drive? | MrBean | DIY-CNC Router Table Machines | 31 | 03-30-2007 09:48 PM |
| Way-Train/Cantek Bandsaws? | Chuck Reamer | General Metal Working Machines | 2 | 02-12-2007 08:45 PM |
| gear train/motor | KEYTEEM | Industrial Hobbies (Support forum) | 2 | 12-21-2005 10:53 AM |
